05-09-2021 09:20 AM
I have noticed that my R5 in constantly change the default memory card. This happens with playback settings, video etc. I want my camera to always use the much faster CF Express card instead the SD card but it seems to prefer the SD card as default. I am always changing it back to the CF card but it changes back again. I think this is happens when I remove the CF card to export pictures from the card to the computer and then by mistake I power on the camera w/o the CF card installed. Of course I would assume things would default to the SD card. But when I put the CF card back in I want to to again default everything to the CF card. I have the camera set to "record to multiple" I never take pictures w/o both cards installed but occasional I will power on the camera w/o the CF card installed and it resets the default card. The SD card is just used as a backup.
05-09-2021 09:33 AM
@sparkycpg wrote:I have noticed that my R5 in constantly change the default memory card. This happens with playback settings, video etc. I want my camera to always use the much faster CF Express card instead the SD card but it seems to prefer the SD card as default. I am always changing it back to the CF card but it changes back again. I think this is happens when I remove the CF card to export pictures from the card to the computer and then by mistake I power on the camera w/o the CF card installed. Of course I would assume things would default to the SD card. But when I put the CF card back in I want to to again default everything to the CF card. I have the camera set to "record to multiple" I never take pictures w/o both cards installed but occasional I will power on the camera w/o the CF card installed and it resets the default card. The SD card is just used as a backup.
That happens with all dual card slot Canon cameras. I am assuming it's a safety feature to be sure you don't "record" to an empty slot.
Maybe if you configure C1 custom settings to use the CF slot (and don't have update switched on) you could just switch to C1 after replacement of a card.
