02-09-2015 11:34 AM
Anyone experience a slightly faster video playback on the T4i? Not sure if it's Quicktime or a setting or lense. The quality is great, but the speed is only a fraction of a second faster. Most of my recordings are of dance routines and I can see a little difference but it is very minor but I would like to correct that if possible.
02-09-2015 10:31 PM
You mean when you're playing them back on the camera or in the computer?
This sounds like it could be a drop-frame issue, if you're talking about really long clips.
02-11-2015 12:20 AM
When I playback on the computer. I copy them over from the media card and play using Quicktime. The videos appear to be just a little faster than 1x speed. I double check the playback on the camera and it seems to be correct in speed. Am I doing something wrong in the transfer method? Is it my media card? Or the media software?
My usual clip is about 3-4 minutes long. I was going to experiment with my video settings. Is there a setting that would be ideal for a sport like basket ball?
02-15-2015 04:34 PM
That definitely doesn't make much sense. The frame rate is "baked in" to the video file, so it's not related to how you transfer the files. If there's an issue, it's definitely on the computer/media player side, not the camera or your workflow.
Usually for sports, you want to use a high frame rate mode, like 720p60.
02-26-2015 10:14 AM
I've experimented with a few settings and the one you recommended works great. I believe that was my issue, the video setting. All is good now. I appreciate your help!
