10-30-2024 01:40 PM - edited 10-30-2024 01:42 PM
For the Canon r5 mark ii (r5ii), is there any way to have minimum shutter speed during auto-ISO in VIDEO aperture priority mode? I know for stills this is possible with that minimum shutter speed setting OR by limiting the range on the yellow menus, but this only applies to stills. I was hoping it could apply for video too to make sure the shutter speed is never slower than the 180 degree shutter angle rule. Right now for 4k 60p, it always goes to 1/100 as minimum when I want it to be at least 1/125 minimum. There seems to be no way to set this limit for video
10-30-2024 05:10 PM
You can make the feature request on the Canon USA homepage. Select [+]Feedback in the upper right-hand corner. Then Product.
10-30-2024 02:47 PM
This is not currently possible in Video Mode based on the manual.
You can set the shutter speed range for each [Shutter mode]
Shutter mode] option. In [Fv], [Tv], or [M] mode, you can set the shutter speed manually within your specified range. In [P] or [Av] mode, or in [Fv] mode with shutter speed set to [AUTO], the shutter speed is set automatically within your specified range (except for movie recording). Select [OK] to register the setting.
Mech shutter/elec 1st-curtain
Lowest speed: Can be set in a range of 30 sec.–1/4000 sec.
Highest speed: Can be set in a range of 1/8000 sec.–15 sec.
Electronic Electronic shutter
Lowest speed: Can be set in a range of 30 sec.–1/16000 sec.
Highest speed: Can be set in a range of 1/32000 sec.–15 sec.
10-30-2024 03:45 PM
Thank you for confirming it. I do hope they add it with a firmware update. The sony cameras are able to do this, so this threw me off a little when transitioning.
10-30-2024 05:10 PM
10-30-2024 05:37 PM
Ohh will do. Thank you
01-24-2025 08:24 PM
I think it’s crazy that the minimum shutter speed adjustment or setting a manual minimum shutter speed for autoISO only works in P and Av modes and doesn’t work in Fv mode. To me that’s a major inconsistency and is a knock against using the Fv mode. It’s a shame really because I like the versatility of the Fv mode. Canon doesn’t consider it a bug because the manual says it only works in P and Av.
