90D Shutter count
Mathiman58
Hi I'm brand new to this and not very Tech Savvy so please excuse my ignorance. I own a Canon 90D and I am finding it impossible to get the shutter count from it? I have tried every online solution, watched every Youtube video, tried every online Shutter count application and downloaded every Canon software available. I was reliably informed that the EOS Utility would do the trick but the download I did does not have the Utility 3 option which, apparently is the one I need? I have tried the Canon connect app on my phone but the shutter count info doesn't show? I have tried to get it via Lightroom and Photoshop but that doesn't work either? When I download the Canon Digital Info software it wont recognise my camera? I am very frustrated and confused and am almost at the point of giving up on Canon for another brand. Can someone please help me? Remember to keep your reply simple, I'm not very bright it seems? Thanks
Perhaps if I explain the process differently...  This is the best attempt you have to obtain a value without going to Canon.
  1. Take a photo.
  2. Use the button with the blue arrow on it to view the image.  When that is displayed you should see one of the screens in the image below.
  3. If the shutter count (as indicated by the red arrow on the diagram) does not show, then press the Info button (see image below) on the back of the camera until it does.  90D back.jpg
    The last four digits in that sequence are likely your shutter count.   If it is greater than the number when you first bought the camera it is likely correct.  For further assurance, if you still have a photo you took when you first got the camera, check that the number of the file name is smaller than the one on your screen.
It will help you now, and for resale purposes to have a copy of the user manual, which will tell you all about the camera.  HERE is a link to that manual.  On the top right of the screen, there is a disc icon (3rd from right) click on that to download it to your computer.  It might be worth looking through that.
cheers, TREVOR
Before you ask us, have you looked in the manual or on the Canon Support Site?
"All the beauty of life is made up of light and shadow", Leo Tolstoy;
18 REPLIES 18
Me, too! I just wanted to let them know we can help, just in case a buyer gave them a hard time! 😉
Previously, a third party application in the name CanonEosDigitalInfo was available free on the internet. I have it on my computer and can easily find shutter counts of all my Canon DSLRs 5DII, 5DIII, 1DIV, 7D and 70D. But it failed to get it for 90D. Couldn't find an updated version of that application on the net either.
Here is an example of the screen when I ran the app in May '22.
Thank you for this. I will try this when I get home. Much appreciated
Thank you for the help in finding out the shutter count on the upper right hand side of image replay on the rear LCD.
However, it's a four digit field. My camera will soon hit ten thousand actuations. What happens then? Will the field be expanded to five digits? The shutter life of this camera is rated at 120000 actuations. That means; a six digit field is necessary.
Any suggestions re the above? Thank you in advance.
If you look at that number, it is preceded by a set of three digits, e.g. 100- #### that 100 counter will simply increase by 1 and the right-hand set will start at 0001 again: thus 100-9999 goes to 101-0000
cheers, TREVOR
rs-eos
You could always just estimate it.  If you know the original value of the count as given to you from the prior owner, then add to that the total number of images you've taken over the years.   Even if that's just a guess as how many images you've taken per month or per year.
Ricky
EOS 5D IV, EF 50mm f/1.2L, EF 135mm f/2L, 600EX-RT (x6), ST-E3-RT
EOS C70, RF 24-70 f/2.8L IS, EF-EOS R 0.71x
jrhoffman75
That individual was either misinformed or misleading you. Shutter count information is not retrievable from an image file.
Dire Studio ShutterCount does work.
jrhoffman75
OP said he bought the camera used. File numbers and folders would very likely be irrelevant in that case since the would be little knowledge of what the original owner did.
I appreciate that.  I was trying to find out an easy solution for them.  Of course the most correct course of action is to take it to Canon to get a shutter count, but the OP bought it without a certified one apparently and I wonder how many others will be prepared to do the same.  Anyway, they know the correct course of action now and that's down to them.
cheers, TREVOR
