03-26-2016 04:39 PM
While shooting with my 6d the screen went completely blank and now none of the buttons are working but the shooter.
If I try to turn it on in automatic it goes completely insane, changing all the values and trying to focus even when I'm not pressing the shooter.
has anyone had the same issues?
03-29-2016 02:32 AM - edited 03-29-2016 02:34 AM
"... to hard reset cameras with built in battery."
I don't have a 6D but generally it takes several weeks of non-use for the internal battery to discharge. I doubt you discharged it.
04-02-2016 06:47 PM
@ebiggs1 wrote:"... to hard reset cameras with built in battery."
But he didn't discharge it through non-use. The whole problem was that the camera wouldn't stop trying to do stuff. The takeaway was that he apparently managed to switch the load to the built-in battery until it ran out of power, forcing a hard reset.
04-02-2016 06:51 PM
"She" did 😉 (Paula = Female name)
04-02-2016 07:05 PM
Bob from Boston
"... the built-in battery until it ran out of power, forcing a hard reset."
The built in is just a 'keep alive'. It doesn't run the camera.
04-02-2016 07:06 PM
Paula,
Did you have to reset the time and date?
04-02-2016 07:56 PM
@PaulaCabezas wrote:"She" did 😉 (Paula = Female name)
Yup! Sorry,,,, I obviously wasn't paying attention to the name. No excuse for the implicit assumption either; we have lots of good female photographers (including my wife, Martha). ![]()
06-08-2020 09:53 AM
I'm having the same issue. How did you drain the internal battery?
06-08-2020 12:09 PM
@Photoman44 wrote:I'm having the same issue. How did you drain the internal battery?
Remove the battery and memory card. Turn on the power switch. Hold the shutter fully pressed for at least 10 seconds.
