10-02-2013 12:21 PM
I managed to connect my 6D to my laptop over my girlfriend's wifi the other day. When I came home I wanted to do the same on my own wifi.
Menu -> Wi-Fi function
There I only have Exit/Confirm set/Error details
to choose from
I choose Confirm set and I can see the Basic settings and the name of my girlfriend's wifi, the name of my laptop and her SSID.
But these settings are only for the connection I established in her apartment.
Now I want to do the same here at home. But I can't find a way to add another connection or to change the one I have.
Help!
10-02-2013 12:38 PM
If you go through "connect to laptop" again it doesn't offer you the option to create another connection?
10-02-2013 01:05 PM
But that never shows up!
Or which is the first menu choice I should make to get that option?
10-02-2013 01:24 PM
Beneath the Wifi Enable/Disable line there should be a WiFi Functions line. IF you click that it takes you to the screen with all the Icons, right?
10-02-2013 01:25 PM
10-02-2013 01:36 PM
It should.
But that does not happen.
I get the "Exit", "Confirm set" and "Error report"
No screen with icons.
But I remember that screen from the moment when I set that first wifi connection.
The first connection is registered but I cannot delete it or change it.
And I cannot find a way to add another connection.
10-02-2013 04:29 PM
It worked now.
I didn't realize that I should press Exit to make it work.
"Exit" didn't seem to be the proper button, so I never tried until now.
