11-17-2017 12:28 PM
11-18-2017 08:22 AM
Call Canon service.
11-17-2017 01:51 PM
Do you have more than one battery?
How old is the battery?
Is it a genuine Canon battery or 3rd party battery?
Have you checked the battery status (
Both the 5D III and the 7D have the ability to monitor battery status. You might want to compare them.
If it's an old battery, it's possible that it's warning you that while it may be "fully" charged, the full charge capacity of an old battery isn't very good -- and it's just alerting you to that.
Batteries are like the tires on your car... they don't seem to wear much on just a single trip... but add up all the trips and eventually the wear is noticeable. Except in battery technology both age and the number of recharge cycles count. The electrons like to move around and it's acutally not good to store a battery too long without using it. I number my batteries and try to swap them so each battery gets some use and nothing sits unused too long -- and at the same time I'm also not using the same battery over and over.
After about 3 years... I know I'm probably nearing the end of a battery's useful life (though I've pushed it longer, I know I can't really expect much longer).
11-17-2017 04:34 PM
"Both the 5D III and the 7D have the ability to monitor battery status."
Provided you are using real deal Canon batteries. Some third world batteries do not have that ability build in them.
11-17-2017 05:14 PM
11-18-2017 08:22 AM
Call Canon service.
11-19-2017 02:45 AM
11-19-2017 01:28 PM
11-19-2017 01:45 PM
@gacemite wrote:
Thanks one again, I removed the SD card From the 5d mark iii to use in another camera, and I try to on the camera and the camera power on, when I insert the card the camera is off, then I remove the card and battery then the camera on again, please what should I done
Are you saying that the problem has stopped? I do not understand your description of events, but if it is working, then I would worry about it too much. Be warned that it is usually a bad idea to swap memory cards between cameras. It doesn't matter if the cameras are the same model. It is a bad practice.
Reformat the memory cards in the camera that is using the card. If it is the SD card, be sure to perform a "low level format".
11-20-2017 01:03 AM
11-20-2017 12:36 PM
If the camera wont power up with the card, then reformat the card. You wont be able to reformat it in camera, but you should be able to reformat it on your computer ... which hopefully allows the camera to start with the card in the camera. Assuming that works, then I would still perform another low-level format using the camera to do the format (cards should always be formatted using the camera where the card will be used. Do not swap cards across devices -- a card would basically be designated for use in that camera only.)
Memory cards can be flagged as "bootable" (this is how Magic Lantern works -- the Magic Lantern firmware isn't installed in the computer, it's just on the memory card but the card is flagged as "bootable" so it boots the card firmware instead of the in-camera firmware). However... assuming your card has been flagged as bootable, the camera isn't able to boot from it.
If the memory card is 32GB or smaller then you would format it with a FAT32 filesystem. If it is larger than 32GB then it needs an exFAT filesystem. exFAT can be tricky because I've noticed different OSes tend to use different blocksizes and some devices don't necessarily support just any blocksize.
If this doesn't work, then you need to get a new memory card.
