10-23-2019 06:33 PM
HI, my 5d mark iii went black. it doesn't show picture on the lcd, and just black picture on the sd card. I can see the menu. I did reset all camera settings, custom setting, took out battery and card, put back in different order.... What else can i try????? Thank you
10-24-2019 12:59 AM
Hi eszter,
There may be some settings that are causing this, like severe underexposure or flash being out of sync. What mode are you shooting in, and does it behave the same way in the green auto mode? I'd also recommend trying with a different lens, or potentially no lens at all, to make sure it is a camera issue and not a lens problem.I would recommend trying these in a room where there is plenty of light just to rule out other environemtnal factors.
10-24-2019 02:31 AM
10-24-2019 03:39 AM
You're welcome, Eszter.
If it is behaving the same way in the auto mode in daylight with multiple lenses, then you may be experiencing a shutter or sensor issue since the menu options are displaying properly. It is probably best to have it checked out by a technician in that case. I'll include the link for you here.
https://www.usa.canon.com/internet/portal/us/home/support/service-repair
10-24-2019 09:05 AM
