03-29-2013 02:06 PM
Got my 5D Mark III a couple of days back. I took a few pictures in RAW-JPEG. While I tried to download, it launches EOS Utility(latest version) and hangs. I tried the same CF card on 40D and it was able to import without problem. I tried other software like Picasa, Adobe Bridge, iPhoto, Picasa and Adobe are not able to connect to the camera. EOS Utility is able to connect and I was able to remotely control the camera and take photos. I was able to download JPEG only files as well. But when it comes to Raw, the software goes unresponsive and loses connection. Once in a while everything works fine as well (even RAW), that is the strange part
My Computer and softwares are up-to-date. Infact the 5D MIII I got through CPS Load worked fine without issues. I also made sure the CF Card and Cable are also fine.
Is it a known problem? or should I return the camera. Thanks in advance for your response
03-29-2013 02:29 PM
Hi pgsdeepak!
So that the Community can help you better, we will need to know any error messages you're getting, and the Computer Operating System you're using (Windows XP/Vista/7/8 or Mac 10.x). Any other details you'd like to give will only help the Community better understand your issue! Thanks and have a great day!
03-29-2013 04:48 PM - edited 03-29-2013 04:50 PM
@pgsdeepak wrote:Got my 5D Mark III a couple of days back. I took a few pictures in RAW-JPEG. While I tried to download, it launches EOS Utility(latest version) and hangs. I tried the same CF card on 40D and it was able to import without problem. I tried other software like Picasa, Adobe Bridge, iPhoto, Picasa and Adobe are not able to connect to the camera. EOS Utility is able to connect and I was able to remotely control the camera and take photos. I was able to download JPEG only files as well. But when it comes to Raw, the software goes unresponsive and loses connection. Once in a while everything works fine as well (even RAW), that is the strange part
As @Stephen said, any additional info about your system will help indeed.
In my case I'm using Win XP 32 bit in this machine and don't have any problems at all to download RAW+JPG.
I'm using the bundled software that came with the camera (CD/DVD), still didn't update it.
- Just in case, why don't you try uninstalling EOS Utility software and all its additional components, and reinstall it again from the CD/DVD? At least to discard a software malfunction.
- BTW, we found that many USB cables worked fine with 5D Mark II but not with 5D Mark III. After changing the USB cable we were able to connect the camera to the computer without any problem. Sounds weird, but after some use the connectors of some USB cables loosen and don't work properly on some cameras or devices.
Regards
03-30-2013 02:52 AM - edited 03-30-2013 02:56 AM
Interesting thread...funny...I have no idea my 5D3 can connect or not. I have always used a card reader to download my pictures from the cards and never connected the camera to the PC in all these years...
Anyway...it's just a guess but if the program lets you download jpeg and not RAW then the program works and recognizes your camera...it's highly likely that there's an option to download only jpeg, only RAW or both somewhere in the software...might be worth taking a look.
04-03-2013 11:21 AM
04-20-2013 10:28 PM
Hi pgsdeepak,
I have the exact same issue. I am running Mac OS X (10.7.5) and have tried the full range of Apple Aperture, Adobe Lightroom and the canon EOS utility tool. All of them simply freeze. This is very frustrating. Downloading the pictures on windows works just fine... So no idea who to blame. What also works is, when I take pictures with the 5D Mark III (in RAW format) and then put the card into my 50D to download them on the Mac, so the files themselves seem ok...
I hope someone at CANON will respond to this, so I won't return my $3.3k camera to amazon.com.
If someone else has found a solution/workaround I would be more than happy to hear about it!!!
Best Regards,
Marco
04-21-2013 12:22 AM
My 5D is also setup to record separately: RAW to CF, JPG to SD. Both cards are Sandisk Extreme Pro. I connect my camera directly to my PC (Win 7 64), EOS util launches, and all images get transferred correctly to my download folder. I (later I pull them into LR). I have not had any issues with dual card file transfers (knock on wood)
Have you been successful with just RAW only transfers?
By chance are you connecting your camera to a USB 3.0 (blue) connector? I know 3.0 is backwards compatible, and it's a long shot, but I've seen some weird stuff with 2.0 devices connected to 3.0. Just an idea and a long shot but it might be worth looking into.
A couple of other things to try in case you haven't already:
1. Format both cards on your PC (full not quick) then format again from your camera.
2. Reset your camera to factory defaults
3. Make sure your camera firmware is the latest
04-22-2013 06:56 AM - edited 04-22-2013 06:57 AM
Hi marcosf,
If you are able to download the images from your EOS 50D and not your EOS 5D Mark III, this may be as simple as the version of software you are using.
What version of EOS Utility are you using?
What version of Lightroom are you using?
04-22-2013 10:57 AM
Hi Mike,
here is an overview of the software versions:
OS: Mac OS X 10.7.5
Canon EOS Utility: 2.13.3 (2.12.3.1)
Apple Aperture: 3.4.3
Adobe Lightroom: 4.3 [865747] - (this is a trial version and it's trial period ran out already - so I won't be using it anymore)
(in general: every program(incl. OS) is up-to-date)
Kind Regards,
Marco
04-23-2013 08:06 AM
marcosf,
There is a newer version of EOS Utility than version 2.12.3.1. Version 2.13.0 can be downloaded from the Canon USA website below:
Please try downloading and installing the update to this newer version and see if that does not resolve the issue.
