01-29-2021 10:04 PM
Hello,
This is what I am hoping is a setting issue, I have however tried just about everything and read everything I can find out there and have not found a solution. The AF seems to work in live mode. The AF in ANY other mode tries to work but does not focus on any target, just goes through the cycle of trying to locate a target then stop, from one end of the spectrum to the other no focus no beep. I have tried every AF mode I can find. It seems the AF mechanisms are working but it just can not see. I have reset all functions and settings multiple times. Anyone? Thanks folks!
01-30-2021 09:24 AM - edited 01-30-2021 09:28 AM
@chriserben wrote:Hello,
Welcome to the forum.
That problem is frequently caused by an inadvertent setting. You stated you reset all camera settings and custom functions.
A possibility is some foreign material like sensor dust on the AF sensor.
https://community.usa.canon.com/t5/EOS/Auto-focus-stopped-working/td-p/152170
Set the camera in manual sensor cleaning mode, to lift mirror, and carefully use a squeeze blower to blow off the AF sensor at the bottom of the mirror box.
01-30-2021 09:52 AM
What lens are you using? Does the camera have sufficient light and contrast for the AF system to function?
01-30-2021 10:36 AM
It sounds like the AF chip in the mirror box is bad.
01-30-2021 12:38 PM
I have tried many lenses in all light conditions.
01-30-2021 12:44 PM
01-30-2021 12:48 PM
01-30-2021 01:21 PM
01-30-2021 03:10 PM
I suppose it can be replaced, it is the alignment that is hard.
