5D Mark IV Shows "FULL" when trying to remote shoot using Digital Photo Professional 4
Rational1
If I use WiFi to tether my Mark IV to my Windows 10 desktop computer I can successfully open Digital Photo Professional 4 and control the camer, EXCEPT for actually taking a picture.  When the shot is composed and ready to take the message window to the left of the on-screen shutter release button has a warning message that states "No more shot [sic] is available."  If I press the shutter release on the camera the topp display flashes "FULL" in the upper left corner where white balance is displayed.   There is a freshly formatted (in camera) SD card and a freshly formatted (in camera) CF card.  If I close out of the EOS utility I can shoot thousands of photos.  Any advise on what I am doing wrong that causes the remote shooting window to show "FULL" ???
26 REPLIES 26
You're welcome. Actually I have found one issue with the software. It will not let me change the target directory from the default one in My Pictures\yyyy-mm-ddd to anything else. It says that it does not conform to the default operating systems requirements. Odd... I shall investigate more when I have time.
Good luck with this - trouble shooting is challenging!
cheers, TREVOR
The "default directory" reported by DPP seems to be whichever folder that you are browsing through when you click [Remote Shooting].  It seems to give you a choice of the current folder you have open, or the option to select another one.
@Rational1 wrote:
@Tronhard  Thank you, that was a very helpful clarification, and a thought process I would not have managed without you spelling it outSmiley Embarassed.  I will re-install the firmware (if it will let me, given that the versions are the same) and if that doesn't work then I'll report back here and contact Canon.  I agree with your logic and it seems the best way to isolate the issue, since everything else appears to work as expected.
It sounds like the EOSU cannot communicate with the camera, at all.  Can you set the time in the camera with the EOSU?  Can you download files via USB with the EOSU?
@Waddizzle  Yes, The EOSU can set all camera settings, change storage locations, download images - again, everything works perfectly except the "FULL" warning which disables the shutter button (whther tethered vis USB or WiFi).
Does your app have write access to the folder?  You might try running the app as administrator.
@CaliforniaDream You, my friend, are a genius! The "FULL" is, in fact, referring to the destination volume. While DPP4 can read, edit and save files in the folder I had selected, when I launch the Remote Shooting app (from DPP4 or EU the Remote Shooting process appears to be unable to write to the folder, thus reporting it as "FULL". If I change to a different directory in DPP4 or EU (it must be a local drive) eveything works fine. Odd that DPP4 can read and write to the folder but the remote shoting window cannot, but you have identified the problem and I can work around it by choosing a local directory. (Running the app as Administrator does not help, just an FYI) THANKS !!!!
Well done @CaliforniaDream and glad @Rational1 got past this without having to send it in for a potentially expensive analysis and likely non-repair.
cheers, TREVOR
