11-22-2015 04:08 PM
Hi Experts,
I need some help. I've tried everything I know. I've done the AF Microadjustments test and it came out great. Both wide and telephoto. I've removerd the filter. I've shot on a tripod with and without the IS on my lens. I don't know what else to do. I have attached a photo of an eagle that I cropped. It was approx 100 yards away. He was still and I was resting on a fence. As you can see, it's not very sharp. All my pictures come out like this, not tack sharp. Any help/advice would be greatly appreciated.
02-25-2017 03:08 PM - edited 02-25-2017 03:09 PM
I cannot imagine that combination would not yield very sharp pictures.
I use the 100-400 II for birding on my 6D. I realize it is a different body but I would think the cababilities of the Mark III would be great enough to provide you with spectacular pictures. Do you maybe have a freind that is a birder that you could have use your camera and see what kind of results they might get with it? That would eliminate any errors on your part anyway.
Just as an example I shot this one with my 6D and 100-400 II. He was probably 75-100 yards out and this is a crop of the original and I have never done any of the 'micro adjust voodoo' either. By the way, your example image above is very small and hard to see any kind of detail.
02-25-2017 06:10 PM
Mark iii with 100-400 lens produces this soft image. Shot on tripod, decent settings. Nothing is sharp. But I Will try that. I think it is some incorrect setting. Thanks.
02-25-2017 06:40 PM
You are concerned with the overall shot? Focus adjustment will not likely help if that is the case.
If I were you I would set up a test with a stationary target. Put the camera on a tripod and do the necessary test. That is the only way you can know if there is a problem. I don't own the version II but I have used it and have several friends with one. They are all pretty good.
It seems to me that all the super zooms out right now are pretty close in IQ. The 100-400 II and the SIgma 150-600 S are nearly identical in IQ.
Do the test!
02-25-2017 06:41 PM
"Just as an example I shot this one with my 6D and 100-400 II."
And a darn nice example, I'd say. Good job. ![]()
02-25-2017 08:04 PM
Done that. Test shot OK not extra crisp.
02-26-2017 02:30 AM
@DOUGALBERT wrote:Done that. Test shot OK not extra crisp.
A short reply like that leads me to believe that your "test shot" [test shot, singular] may not have been very meaningful. If you want to take meaningful test shots, one way is to go through the motions of taking test shots for an AFMA adjustment. The "Dot Tune" method is fairly well documented. I suggest you try that.
Taking just one test shot tells you absolutely nothing. Nothing. When making an AFMA adjustment, one would typically take many test shots. You take numerous test shots because each shot will vary slightly. By taking numerous shots, you can discern whether or not the source of the variance is your testing methodology, or your gear.
02-26-2017 04:01 PM
Did take 20-30 shots. Three different times and locations
02-26-2017 05:06 PM
You need to contact Canon.
02-26-2017 08:13 PM - edited 02-26-2017 09:07 PM
@DOUGALBERT wrote:Did take 20-30 shots. Three different times and locations
Please review the Canon Microfocus Adjustment Guidebook.
One of the key things to note is they recommend putting your focus target on the ground, so you can see on the grass or carpet where the camera is actually focusing. If you just photograph a vertical target, you can't tell if the camera is front or back focusing.
01-17-2018 04:34 PM
I came to the same conclusion. Today, a cloudy day in Sarasota, FL, I took some time to do some lens comparisons. I own the Canon 500 prime IS, the Canon 100-400 version II, and I also have the second generation 1.4 extender. I compared these on the Canon 7D MkII and the Canon 5D Mk III. I shot all exposures at iso 800, f8, and whatever shutter speed the conditions landed me. (That was about 1/1600 sec in afternoon cloudy conditions.) Most of my configurations yielded very good, and very similar results, with slight differences. For example, the 1.4 extender, with either the 7D or the 5D, resulted in very slight, barely noticeable sharpness reduction. My best results, on both bodies was with the 500 prime without the extender, as expected.
(I did not bother to try the 100-400 with the extender, as I don't intend to use it that way.)
Here's what surprised me: There was a very noticeable difference between the 5D MkIII with the 100-400 II and the 7D with the 100-400 II. The 7D definitely yielded sharper images. I tried the test again, to confirm, and got the same results. I don't know why the image quality is so noticeably reduced on the 5DIII, but I've decided to avoid that configuration. The good news, I suppose, is that the 100-400 (at 400) is really excellent on the 7D Mk II. It's almost as good as my 500 prime.
