04-05-2016 07:27 PM
I just received my 2nd 5D III from Adorama, an open box purchase, which interestingly has the same exact issue as the one I returned. I have power off set for 2 min which it does. But no matter what key I press, including the shutter button, menu, review, etc. it will not turn back on. I have to physically turn it off then turn it back on. This is my 5th digital eos dslr including a 7D, 7DII, 5D and 5DII, and a couple of rebels.so I am familiar whith how this should work. I tried different lenses but no change. I am prepared to return this one but wanted to check here first. I have ordered open box items before and they always appear to be brand new or near brand new with no issues. Is this something that is peculiar to the 5D III? If I am overlooking something please let me know. I am starting to feel a little stupid about this.
04-05-2016 07:44 PM
Did you get yours back? 8^)
04-06-2016 09:58 AM
Return it, again.
But, this time include a letter stating what the serial number is of the unit you're returning is exhibiting the same issues as your prevous unit. Phrase it in such a way as to sound helpful, as if you suspect that they may have gotten a bad batch of cameras, not as if you're suspecting that they returned the same unit back to you. Play dumb.
04-06-2016 12:52 PM
Thanks for the reply. It is definitely going back. I did more on-line research and the problem seems to be in the battery box and/or motherboard.
04-06-2016 10:41 AM
Hi 32degrees!
To help us and the community determine what could be causing this, we'd like to ask a few questions if you don't mind answering.
Look forward to your reply!
04-06-2016 01:14 PM
It is more sporadic now. It happens with or without lens. Tried 3 different lenses: my tried and true 24-105, 70-200, and 24-70, 2 Lexar 32 gig memory card, and 3 different batteries. Memory cards and lenses don't seem to impact it. Happens whether camera is fully dressed or not. The last battery change seemed to help. Camera was cleared to defaults when it arrived.
