06-01-2015 04:29 PM
my 100-400 ii won't autofocus with a 1.4x iii on an EOS 70D. When I install the teleconverter, the camera automatically switches from AF Servo to M Focus.
Solutions?
06-02-2015 11:41 AM - edited 06-02-2015 11:42 AM
@jsfarnsw wrote:Thanks everyone. I did not realize the AF systems required that much light to work properly.
AF needs adequate light to work reasonably fast and reliably.
Do an internet search about teleconverters and taping up some of the contacts. This "fools" the camera into not realizing the converter is there, so that it will still try to AF the lens. Just don't expect focus to perform very well. It will be slower and in lower light situations or with low contrast subjects it may hunt a lot and even fail to achieve focus. There's a reason Canon sets a limit and turns it off, when a lens/teleconverter combo exceeds the rated AF capabilities.
You'll have to find a website where someone illustrates which pins to tape up. I haven't done the tape trick myself... I simpy don't bother with TCs on lenses where it would exceed the light levels, or in a few cases I just manually focus (500/4 with a 2X on it, for example).
7D Mark II (not the original one), 5D Mark III (not the II or original), all 1-series (film and digital) and the EOS-3 film cameras are "f8 capable", meaning that they can still AF (mostly with one center AF point only... 5DIII can use a small group of points in the center I believe) when a lens + TC makes for an f8 or larger aperture. All other Canon cameras, including 70D are "f5.6 capable".
The 100-400mm is f4.5-5.6 already... so adding even a weaker 1.4X, makes for an f6.3-f8 combo that exceeds your camera's design capabilities. But some folks manage to make it work to a limited extent with a few small, carefully placed pieces of Scotch tape!
Note: There are a few third party lenses that are f6.3 even without any TC, yet still AF... probably by similarly "fooling" the camera.
Alan Myers
San Jose, Calif., USA
FLICKR & EXPOSUREMANAGER
02-12-2021 11:22 AM
What a surprise to get notifications that someone was resurrecting this zombie thread!
The fix for me was to sell my EOS 70D and purchased an 80D, which will autofocus at f/8. I have since added a 90D to my kit and I've replaced the EF 100-400mm with a 400mm f/4 DO. The only thing I kept from those days was the 1.4x teleconverter. Amazing how equipment upgrades can solve an autofocus problem.
06-03-2015 12:22 PM
@jsfarnsw wrote:I stand as a case in point. I own one camera, an EOS 70D, and one lens, the 100-400mm ii. And a 1.4x iii converter.
Yeah, but you didn't pay $11,500 for that lens. If you had, I daresay the 70D wouldn't be your only camera.
06-03-2015 01:58 PM
06-10-2015 07:04 AM
06-10-2015 12:01 PM
09-01-2017 01:13 AM
09-01-2017 07:37 AM
See this
Do do your cameras have an f/5.6 autofocus limit.
09-01-2017 09:21 AM - edited 09-01-2017 12:01 PM
@Thebellanger wrote:
Hey folks how is everyone? I recently purchased an older Canon 500 mm f 4.5 zoom lens. I tried the 1.4 converter mk 3 and it did not autofocus on my 70D or my 5 D3 very disappointing any suggestions?
You say it's a zoom lens, but you don't specify its focal range. Is it a lens that's 500mm at the long end, but f/4.5 at the wide end? If so, and if it isn't a "constant aperture" lens (i.e., one whose maximum aperture is the same throughout its zoom range), it will be slower than f/4.5 anywhere but at the wide end. But a 1.4 teleconverter subtracts a full stop from a lens's maximum aperture throughout its zoom range. IOW, it turns f/4.5 into f/6.3, and only a few high-end cameras can autofocus at above f/6.3. Which means that at best your 70D will autofocus only at the wide end of the lens's range. Your 5D3 can do a bit better; but unless your lens is f/5.6 or better at the long end, even it won't be able to autofocus over the full range. So you're probably going to be limited to manual focusing most of the time.
09-01-2017 09:46 AM
Yet another reason why t-cons are a bad idea at best.
09-01-2017 10:00 AM
"Yet another reason why t-cons are a bad idea at best."
Not true - they can serve a useful purpose. One just needs to read the appropriate documentation and be aware of any limitations.
09-01-2017 12:28 PM
Ultimately, I sold my 70d and purchased an EOS 80d. Problem solved.
