06-11-2013 03:14 PM
Hi
I am looking to buy "the next lens" . Preferably a macro lens but i am confused.
I currently have a 18-55mm and 50mm lens. I mostly capture landscapes and flowers.
Tks
Zinta
06-11-2013 08:48 PM - edited 06-11-2013 08:50 PM
06-12-2013 01:04 PM
Well - I think that depends on what you want to use the lens for? Far away? Close up? You're tempted by Macro, the L Series macro is amazing, but I found myself not usign it as much as I thought due to the fixed length. Honestly the upgrade to the 24-70 2.8L made a HUGE difference in my photos, and landed me more gigs to purchase future lenses/.
06-13-2013 05:58 PM
Wow, if I were in your boots, I would defintly look at a Canon EF 100mm f2.8L IS USM macro. The cost may seem a bit high, but you will use the IS option more than you may think. The non IS model, lens wise is good, but you will find in bushes, shrubs, rose bushes, it is much more comfortable to shoot hand held than with a lens camera and tripod. The Canon EF 100 "L" lens can drill down to 1:1 for those tight macro images. If you decide to shoot some bugs, you can get within 11.5 inches and still have great focus, any closer, you'll need a extenison tube. Not knowing what you are using for your landscapes now, I would suggest a Canon EF-S 10-22mm f3.5-4.5 USM. This lens is razor sharp, and considered a Ultra wide angle. It can also be used for close-ups, and portraits. For some real close up work you may want to use a set of extension tubes. The EF-S 10-22 does not come with IS, so shutter speeds below 1/250th second must be used, and a high ISO to keep jitter down when hand holding. You can always use a tripod for the landscapes you may want to take. I use mine even in low light to get some rather nice after dark city scapes of New Orleans.
06-11-2013 03:54 PM
Hi zinta!
Welcome to the Canon Forums! So that the Community can help you better, we will need to know exactly what equipment you're using, and the types of macro shots you intend on taking. Any other details you'd like to give will only help the Community better understand your issue! Thanks and have a great day!
06-11-2013 04:32 PM
There's no wrong answer, everyone has different styles and preferences.
But the 100mm 2.8 macro is an amazing lens. It's a focal length you don't have, and much, much sharper than anything you don't have. Otherwise, I'd get a telephoto.
06-11-2013 06:28 PM
Thanks Stphen.
I am using a canon Rebl T3. I want to take macro shots of flowers , water drops .
06-11-2013 06:29 PM - edited 06-11-2013 06:35 PM
I will look into the 100 mm lens.
Also if im to consider Telephoto which one is better
Canon EF 75-300mm f/4-5.6 III Telephoto Zoom Lens or
Canon EF-S 55-250mm f/4.0-5.6 IS II Telephoto Zoom Lens
Thank U Skirball 🙂
06-12-2013 09:01 AM
Thank you scott 🙂
06-12-2013 01:04 PM
06-13-2013 05:58 PM
06-14-2013 11:44 AM
oh !Well i really have think my options about 100mm , since it is fixed length..I will look into the 24-70 2.8L.
Thanks davdgreat ..
