Zoom Lens Recommendation for Rebel t7i
SarelErwee
Amateur/recreational photographer. I take pictures almost exclusively on hiking/outdoor excursion trips. After a trip to Alaska, I realized I need a zoom lens. What zoom lens would you recommend for photographing animals from a kayak or boat or for generally better/closer hiking photos?
EF-S 55-250mm f/4-5.6 IS
Canon EF 75-300mm f/4-5.6 III —- thoughts either of these?
I definitely want image stabilization and also want to stay in the lower price range. Thanks in advance!
20 REPLIES 20
MikeSowsun
I guess we were all wondering why you would point out that a 70-300 “full frame” lens would yield an equivalent 112-480mm, but you didn’t also say that the 55-250 “kit lens” would yield an equivalent 88-400mm.
Mike Sowsun
Never noticed my 75-300 didn't have IS until now.
John
ebiggs1
I am another vote in favor of you getting the EF-S 55-250mm f/4-5.6 IS STM Lens. I am not a fan of any of the lenses in the 70-75 to 300mm zoom range.
I know you stated you wanted to stay in the lower price range but the EF 70-200mm f/4L IS USM Lens is an  outstanding lens and better than anything listed here so far. It is built to take more abuse that might occur in riding in a canoe. It is quite a bit more expensive than the others but, IMHO, well worth it. It is a lifetime lens purchase.
EOS 1DX and many lenses.
exactly.
I don't know that I would take my L-lens in a kayak. 8^).
ebiggs1
A lens or any camera gear you don't use because you are afraid is not worth a dime. Not a penny.  It all works well in a camera bag or on the shelf. If I go there, my gear goes there with me.
Agree.
I don't ocean kayak or whitewater kayak, just flatwater. I use a drybag that I can place between my legs and the camera sits it till I want to use it.
The new EF70-300 version II lens is quite good. I don't think any of the 75-300mm versions are good.
@shadowsports wrote:
KV,
.  The perspective does once you put a FF lens on a APS-C sensor.
There you go again, on an APS-C size camera the perspective of the EF 70-300 set at 200 mm will be exactly the same as the EF-S 55-250 set at 200 mm.
jrhoffman75
"The perspective does once you put a FF lens on a APS-C sensor."
This is correct if one is comparing using a 200mm lens (for example) on a FF camera and then puts that lens on a crop sensor camera. But if all anyone has is a crop sensor camera then an EF and EF-S lens will show exactly the same view.
But in this case, the OP might never had seen a "35 mm" or "FF" camera, so to EBiggs point, why bother to bring it up, since the OP has no frame of reference.
