Will Lens From an EOS Rebel XT Fit On a PowerShot SX540 HS?
sorumhar
I have a Canon Rebel XT with a telescopic lense.  Will this lense fit a Canon Power Shot Sx540hs
Tronhard
VIP
VIP
The Canon PowerShot series have a fixed lens that is not detachable, so it will not accept other lenses.
cheers, TREVOR
9 REPLIES 9
Tronhard
VIP
VIP
cheers, TREVOR
Thank you very much.
You're most welcome.  If you don't want to get lots more updates on this, please mark my post as a resolution, then people will know it's sorted.
cheers, TREVOR
I did.
ebiggs1
While marking this post as solved, doing so may only save an incorrect answer. More replies can be more enlightening even with more correct answers. A lot, quite a lot, of the answers here are opinions and not fact.
EOS 1DX and many lenses.
Hi!  We changed the solution designation on this thread to point to the post with the actual answer.  Thanks for catching this!
normadel
I don't understand what's going on with this topic.
Does someone think Tronhard's original reply was in error? It was not.
We prefer that what gets flagged as the solution be the solution itself--the "try this" statement--rather than the follow-up where someone would claim that "it worked."  We made sure that's the case here.
Intended the OP to flag the solution for the reasons you indicate.  Obviously, I should have phrased the suggestion differently!  Congratulations to eagle-eyed Ernie for catching that, and to Danny for making the correction! 👏
cheers, TREVOR
