Tripod Collar seized on 100-400 ii
ivejar
Has anyone out there had the tripod collar on the 100-400 ii seize up? Mine won't budge. I've tried everything I can think of and just wondered if anyone else has had success getting it to move.
I've got a workshop coming up in 3 weeks and don't have the time to ship it off for repair.
17 REPLIES 17
Waddizzle
You might try loosening and/or removing the tripod foot, to see if that relieves any stress, pressure, or debris holding the rotating ring in place.
ebiggs1
"... the 100-400 ii seize up?"
What do you mean?  It won't let you turn it?
"I've tried everything ..."
Like what?
This is based on memory of when it first came out & Lens Rentals did their testing but I'm pretty sure it can't be removed like the collar on Ver 1. Removal requires some dismantling.
ivejar
Yes, it can't be removed without dismantling. I have removed the screws completely. Tried putting a few drops of silicone around the ring, etc. It just will not budge.
Tried that. I think I'll need to take it in.
Under the circumstances, are you sure that removing the collar is a good idea? They must have made it a semi-permanent installation for a reason. Maybe the collar is, in effect, a structural member and the lens can become slightly deformed if it's removed.
Bob
ivejar
I don't want to remove it. I just want to rotate it so that I can shoot portrait when using my monopod. It won't budge, but it is supposed to rotate similar to the 70-200.
ivejar
You have made no mention of it, so far.  You are turning the correct knob to loosen the collar?
Is that knob stuck, too?  It might be too hard to rotate the collar by hand.  Mount the camera/lens on a tripod, and then try it.
