Stuck lense
agullage05
Does anyone have any advice on how to get a stuck lense off of my camera. I’ve had many different cameras before and this has never happened. It clicks in and out when pressing the release button but when I try to remove the actual lense it doesn’t come off. Any advice? I don’t have the money to bring it in and get it taken off for $100.
5 REPLIES 5
Tiffany
Moderator
Moderator
Welcome to the forum!
So that the Community can help you better, let us know what model Canon equipment.
Any other details you'd like to give will only help the Community better understand your issue. The forum is not intended for immediate support. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
normadel
What camera? What lens? Was the camera dropped with the lens attached?
ebiggs1
"Any advice?"
You are kidding we always have advice now whether it is good advice or not is for you to decide. First I must ask you are twisting the lens to the left (counter clockwise) looking at the camera when you press the release button? Yes, no?
There is a reason why the lens is stuck since 99.9% of the time they don't stick. Did you drop it? Is it an off-brand rather "inexpensive" lens? To get a better grip you can try one of those rubber pads folks use to remove hard to remove jar lids. But keep in mind this stuff is fairly fragile and you run the risk of further damaging either one or both the lens and camera if you don't use common sense.
I have found the rubber lid gadgets do a pretty good job.
EOS 1DX and many lenses.
stevet1
agullage05,
It sounds like the release button is not engaging the little pin to release your lens.
I'm afraid you might have any other choice than to send it in for repair.
Sorry.
Steve Thomas
Time to send it in for repair unless you plan to use the camera with one lens forever.
Friends and Family
