07-22-2023 03:51 PM
I have an EOS M6 and the EF-M 11-22mm is not working on it. The camera shows a blinking green light and the screen has no image. When I put my 50mm lens on the camera it works just fine. Any ideas or suggestions?
07-22-2023 05:40 PM
Did that lens once work ok with the camera or is it recently a acquired lens?
07-22-2023 08:22 PM
It once worked with the camera. I got the 2 lenses when I bought the camera.
07-22-2023 08:38 PM
Do you have a filter or other device screwed onto the front of the lens? If so, try removing it.
07-22-2023 08:43 PM
No, no filter on it
07-22-2023 08:55 PM
It is looking like the lens needs to be sent in for repair. You should compare the cost of repair to a new or used lens to see if it is cost effective.
07-23-2023 12:42 AM
I"ll have to do that. I haven't found the lens under the cost of $399
07-23-2023 05:54 PM
You can get that lens refurbished from Canon right now for $320. In my experience buying a refurbished lens from Canon is practically like buying a brand new one.
11-07-2023 08:23 AM
I had the exact problem with a refurbished by Canon lens. I RMA'd it and the replacement is supposed to be here tomorrow. Hope this one works.
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
EOS R6 Mark II - Version 1.2.0
08/18/2023: Canon EOS R5 C training series is released.
