Rebel T7 Additional Telephoto Lens
Hamop54
I have the Rebel T7 with an 18-55 mm zoom lense. I want to add the EF 75-300mm f/4-5.6 III USM @$234.99. It's not a $1200 lense but it seems like a match for the camera based on the retail price range.
Any thoughts on this?
I got the Rebel as a gift and have been enjoying ever since.
Hi Dan:
The 55-250 lens that you mentioned in your response is the one I would recommend.  That should do the job very well and it is an economical solution that has good optics.
I would not recommend an extension tube.  They are normally used for extreme closeup work, such as macro photography.  What is normally used to extend the focal length of a lens is an extender, but an extender will not work on either of the lenses I suggested and would be much more expensive in any case.  It's hard for me to assess how big the train will be in your image, but the magnification factor of the 55-250 is obviously going to be 5x over that of your 18-55, FWIW.   I would recommend just getting the 55-250 and see how that works for you.
Reviews from reliable and respected sources are valid, and I do offer only valid ones.  Ernie has a thing about anyone's opinion but his own and he is entitled to that.  I research carefully before purchasing gear and in 40 years it has worked for me - in the end we must each make our own decision.
Good luck with your grandkids.
cheers, TREVOR
28 REPLIES 28
Hi Kevin:
I didn't see your answer in that context. 🙂  My point is that while something might be technically correct, it may not help the OP in resolving their issue as posted.  I have seen cases where the discussion becomes a technical conversation that can leave the OP and their request way behind.  For that reason, I limit my answers generally to what will serve the OP.  In this case, because they don't have the funds, or the camera to use such a lens, I left anything is not specifically helpful to them out of the conversation.
cheers, TREVOR
Thanks!
Waddizzle
The EF 75-300mm series of lenses are typically included with Rebel T5/6/7 camera kits.  They are best described as less than Canon’s best effort.  Look for a used lens.  Do not pay much more than about $100USD for one.
"Fooling computers since 1972."
ebiggs1
"(The saying about boats applies to teleconverters: The two happiest days in a photographers life are when he gets his teleconverter and the day he puts it in a drawer and stops using it.)"
Amen, brother!
Thanks
ebiggs1
"I have seen cases where the discussion becomes a technical conversation that can leave the OP and their request way behind.  For that reason, I limit my answers generally to what will serve the OP."
ebiggs1
As an addendum, the 50mm focal length is a difficult one to use. It usually seems just a bit to short or just a bit too long.
Personally, I generally tell folks unless you have a specific need for a 50mm prime, don't buy one. Especially if it is your only lens or perhaps just your second lens. One very good reason to buy one is, if you need a very fast lens. They come in fast apertures like f1.8, f1.4 and even f1.2.  If you ever find the need for a fast prime look at something in the  30mm-35mm FL. The Sigma 30mm f/1.4 DC DN Contemporary Lens is a fine example. A lens like the Canon EF 35mm f/2 IS USM Lens would be a good choice, too. Again if ever a fast prime is in your sights.
ebiggs1
"The reviews are helpful in that I get some good info ..."
Maybe!  You can't trust reviews. Some are OK and even good. Some are not. The problem is learning which is which. Take them with a grain of salt or as some enjoyable time gulping entertainment but not so much as gospel. You get better info here.
