09-29-2022 09:56 PM
I have the Rebel T7 with an 18-55 mm zoom lense. I want to add the EF 75-300mm f/4-5.6 III USM @$234.99. It's not a $1200 lense but it seems like a match for the camera based on the retail price range.
Any thoughts on this?
I got the Rebel as a gift and have been enjoying ever since.
09-30-2022 11:40 AM - edited 09-30-2022 12:01 PM
Hi Dan:
The 55-250 lens that you mentioned in your response is the one I would recommend. That should do the job very well and it is an economical solution that has good optics.
I would not recommend an extension tube. They are normally used for extreme closeup work, such as macro photography. What is normally used to extend the focal length of a lens is an extender, but an extender will not work on either of the lenses I suggested and would be much more expensive in any case. It's hard for me to assess how big the train will be in your image, but the magnification factor of the 55-250 is obviously going to be 5x over that of your 18-55, FWIW. I would recommend just getting the 55-250 and see how that works for you.
Reviews from reliable and respected sources are valid, and I do offer only valid ones. Ernie has a thing about anyone's opinion but his own and he is entitled to that. I research carefully before purchasing gear and in 40 years it has worked for me - in the end we must each make our own decision.
Good luck with your grandkids.
09-29-2022 10:47 PM - edited 09-29-2022 10:56 PM
Honestly, I would seriously recommend avoid purchasing the EF 75-300 lens series. They are Canon's worst optics and lack image stabilization. The best matches for getting longer shots are the EF-S 55-250 (either STM or USM versions) or the excellent EF 70-300 IS USM lenses - both have image stabilization and good optics. I did a review of the 70-300 lenses AT THIS LINK The 55-250 is an excellent kit lens and there are lots available out there second-hand - Canon have these on their refurbished site, essentially as new with a warranty - see THIS LINK there are also EF 70-300 units from time to time, but not when I just looked but HERE is a link, and you can select to be notified when one is available.
Much depends on the subjects you seek to capture. Can you advise what you will be aiming to get this new lens for and what you will produce - i.e. images for posting on-line or for digital display, or for large prints.
09-30-2022 05:02 AM
Hello Trevor,
I was planning to photograph my grandkids indoors portrait or action shots at soccer & basketball games. Also landscape scenery photos for digital display on my computer or for posting on Facebook.
There's a railroad across the street and I wanted to photograph the approaching train from a street overpass at about 1500 ft or so from the train which is traveling at about 25 MPH. (40KMH)
I've been copying the photos onto my computer and resizing them using ViewNX2, then copying the smaller photos onto my smartphone & sending to friends & family via text messages. Of course the original photos are saved on the SD card in the camera.
My objective to have more magnification than the lense I already have.
Is this one of the lenses you recommended? : EF-S 55-250mm f/4-5.6 IS STM @ $299.99 US
It's more in the price range of what I wanted to spend.
And what about an extension tube: Would that increase the magnification of the lense I already have?
Thanks for providing all the info.
Dan
09-30-2022 10:57 AM - edited 09-30-2022 11:01 AM
Dan,
In spite of Trevor's advice many thousands of folks use the EF 75-300mm f/4-5.6 III USM and love it. It is the lens designed for the T7 and your segment of photographers. IMHO, if I were buying today I would opt for the EF-S 55-250mm f/4-5.6 IS STM over the EF 75-300mm f/4-5.6 III USM. It is a better lens but you will lose 50mm of focal length. A little more expensive for a little less FL but a little better IQ.
Here's the bottom line Dan, most people are not pixel peppers. They want to take photos and snapshots. They want to share them on social media like Facebook. And for that purpose the EF 75-300mm f/4-5.6 III USM fills the bill completely. Would Sports Illustrated or NatGeo use that lens? Probably not but they aren't most people.
I taught DSLR101 classes for a while and in the class of new to photography folks most had a Rebel with the one or two kit lenses. The EF 75-300mm f/4-5.6 (whatever model) was one of the lenses. As a group they all were satisfied with it.
Go to a camera store like Best Buy and check it out before you buy. Check out both lenses. Pick the one that suits you. Whatever you do, stop reading the reviews. They are less than helpful.
Hi Dan:
09-30-2022 11:56 AM
One HUGE advantage that the 55-250 has over the 75-300 is IS (Image Stabilization). It *greatly* reduces the amount of blur due to camera movement.
09-30-2022 01:40 PM - edited 10-04-2022 12:50 PM
I agree with Trevor... Get the EF-S 55-250mm IS STM lens and give it a try. (Slight correction: There is no "USM" version of the 55-250mm. Be sure to get the "STM" version. It will give better focus performance. There are two versions that don't have STM or "stepper motor" focus drive. Those other two versions use a slower, noisier "micro motor" focus drive system.)
The 55-250mm offers much better image quality than the EF 75-300mm III USM. Plus the 55-250mm has IS that is particularly helpful with telephoto lenses, which can be more difficult to hold steady. The EF 70-300mm IS USM lenses Trevor suggests are a good alternative. There are four versions of EF 70-300mm... EF 70-300mm IS USM original and the newer "II"... EF 70-300mm "L" IS USM which is more robust, better sealed for dust and weather resistance, off-white color and has option of fitting a tripod mounting ring... and an EF 70-300mm "DO" IS USM that uses "diffractive optics" to be more compact (but not any lighter weight). All these typically cost more than EF-S 55-250mm... even used or refurbished. The "L", in particular, is fairly expensive. Now discontinued for some time, the "DO" used to be the most expensive of the bunch, but used copies sell for quite reasonable prices today.
An "extension tube" will not do what you want. Extension tubes have no optics in them and are fitted between the lens and the camera to make the lens focus closer, such as for macro shots. While the tube is installed, the lens will not be able to focus to infinity, which is about where you're trying to shoot (1500 feet away) those trains!
Don't confuse extension tubes with "Extenders", which is what Canon and a few others call teleconverters. These do have optics that effectively multiply the focal length of the lens to make a telephoto more powerful (without changing the close focus distance). Common Extenders are 1.4X and 2X.
However, Extenders and teleconverters only work with certain lenses... and neither the EF-S 55-250mm or EF 75-300mm are a good candidate for that. Canon's own EF 1.4X and EF 2X teleconverters won't even physically fit to either of those lenses. They have a protruding front element that needs to fit inside the rear barrel of the lens, and the internal diameter of the 55-250 and 75-300 is not large enough to accommodate the extenders. Some lenses also have rear elements that will interfere with the front element of the teleconverter.
Not to mention, there's always some "loss of light" to teleconverters. Those lenses that are f/5.6 would effectively "become" f/8 lenses if a 1.4X were attached (one stop of light lost).... while if a 2X were attached they would "become" f/11 lenses. In both cases, your T7 will be unable to autofocus. There simply isn't enough light reaching the AF sensors inside the camera for them to work. In order for your camera to autofocus with a 1.4X teleconverter, the lens must have at least an f/4 max aperture. And to be able to autofocus with a 2X, the lens needs to be at least an f/2.8. f/4 lenses are significantly more expensive, while f/2.8 are even pricier. They also are a lot bigger and heavier (more likely to need a sturdy tripod, less likely to be able to use hand held). Finally, there is some loss of image quality whenever more optics are added to lenses. It can be very little, with top quality like Canon's own 1.4X Extender, but increases with stronger 2X teleconverters and can be particularly bad with inexpensive, 3rd party teleconverters.
The EF-S 55-250mm will be great for daytime shots of sporting events or trains. Try it to see if it gets you what you want. Get closer if need be. The 55-250mm will not be all that great for indoor portraits or indoor sports like basketball and offers limited use for outdoor portraits or landscape photography.
In low light (indoor) conditions you need lenses with larger apertures. Zooms with larger apertures are available, but are big, heavy and expensive. And, for that matter, most zooms largest aperture is f/2.8. Another purpose for large apertures is shallow depth of field effects, such as blurring down a background for a portrait shot.
A very affordable lens with a pretty large aperture is Canon's EF 50mm f/1.8 STM. This is more than a full stop larger than f/2.8 and more than two stops (4X) brighter than f/4 (such as the 55-250 has at 55mm). The 50mm f/1.8 is also a compact, lightweight lens. Might even slip into a pocket. Great for portraits and moderately useful for indoor sports (a bit longer focal length such as 85mm or 100mm would be nice, but adds quite a bit of cost).
While a telephoto like the EF-S 55-250mm certainly can be used for landscape photography, that's sort of specialized... Not something most landscape photographers would do a lot. More commonly landscape photographers look for a wide view, which also helps with deep depth of field by making possible sharpness from near to far with smaller apertures like f/8 or f/11 (opposite of the large aperture, shallow depth of field effect so useful for portraits).
Your 18-55mm lens gives you a moderately wide angle of view. Maybe that's enough for you. If so, great. If not, one of the most affordable "ultrawide" lenses is Canon's EF-S 10-18mm IS STM. 10, 11, 12mm etc. make possible dramatically wide shots. This lens is also compact, lightweight and one of the few of this type with image stabilization (very wide lenses are pretty easy to hand hold steady, but IS is a nice addition none-the-less).
Finally, maybe you already know, something that can both enhance your images and help protect your lenses is a lens hood. These are sold separately from all the above lenses, but well worth getting. All the below hoods bayonet fit onto the lens for use and can be reversed on the lens for more compact storage.
Your EF-S 18-55mm IS "II" lens uses Canon EW-60C lens hood. (Note: If you happen to have the EF-S 18-55mm IS "STM" lens, that lens uses EW-63C hood instead. But usually T7 are sold with the 18-55mm II, not with the STM lens.)
The EF-S 55-250mm IS STM lens uses Canon ET-63 lens hood.
The EF 50mm f/1.8 STM lens has a deeply recessed front element, so probably doesn't need a lens hood. However, if you prefer, Canon ES-68 lens hood is available to fit that lens. A hood would be recommended if a filter were fitted to the lens.
EF-S 10-18mm IS STM lens uses Canon EW-73C lens hood.
I hope this helps!
Alan Myers
San Jose, Calif., USA
GEAR: 5DII, 7DII (x2), 7D(x2) some other cameras, various lenses & accessories
FLICKR & ZENFOLIO
09-30-2022 02:16 PM
A nit:
It is generally only the Canon teleconverters that work with certain lenses. My Tamron 1.4 has worked with every lens I throw at it.
(The saying about boats applies to teleconverters: The two happiest days in a photographers life are when he gets his teleconverter and the day he puts it in a drawer and stops using it.)
09-30-2022 02:28 PM - edited 09-30-2022 03:31 PM
If the OP is interested, there is EF-S 55-250 IS STM available from the Canon Refurbished site, essentially as new, with (as I understand it) a 1-year warranty AT THIS LINK for $239.
09-30-2022 05:39 PM
It does help. Thanks for all the info. I will save it here for use in the not to distant future.
