09-24-2023
02:19 PM
08:42 AM
I'm interested in purchasing a 90d DSLR, and have just noticed that in some of the listing pictures on various sites the lens mounted on the camera is a 58mm and in other listings it's a 67mm. I always thought the 90d took a 67mm lens; clearly I was wrong. However I also noticed that the listings with 58mm lenses are less expensive than cameras with 67mm. Could someone explain why the difference?
In advance, thanks for any info.
MMK
09-25-2023 06:16 PM
I believe these listings you are speaking about is showing images of 90D cameras with lenses attached? Typically in such images you end up seeing the front of the lens which includes the filter size value.
As I and others have already stated, that’s not anything to do with the mount.
09-26-2023 01:31 PM
Thank you
