09-13-2022
07:36 PM
08:09 AM
I inadvertently installed the European firmware on my US RF70-200 2.8. Is the European firmware different?
09-13-2022 07:40 PM
I live outside the US, in Oceania, and over the year I have downloaded firmware from the US, Europe etc. and found no disfunction in my gear from doing so. If you have downloaded it, I would simply suggest using the camera as intended and seeing if there are any changes to its operation that don't look appropriate.
09-13-2022 08:07 PM
@dharge wrote:I inadvertently installed the European firmware on my US RF70-200 2.8. Is the European firmware different?
Probably, not. It is not like the lens has a menu system like a camera body would, where language could become a factor. Imagine resetting the camera back to factory defaults and the language changed in the menus.
09-14-2022 01:37 AM - edited 09-14-2022 01:38 AM
Canon firmwares are the same world wide. You can check yourself for example with sha256 checksum.
Language restriction in camera is a hidden on/off feature.
