06-29-2022 12:10 PM
Hi, I just bought this lens and when I carry the camera with lens attached, the inner barrel of the lens slips to full extension. Is this normal or should there be enough friction to hold the inner barrel in place? I would like to be able to move around with it over my shoulder and not have this happen--I'm sure it's not great for the lens and it's a little annoying. TIA.
06-29-2022 03:10 PM
Actually, the Rf 100-500 has a white knurled ring, jut behind the focusing ring. It provides a variable friction effect to dampen or stop the lens from extending. There is a lot of heavy glass in the front barrel of the lens, so it will want to drop if being carried. The benefit of the ring, as opposed to a switch, is that one can vary the tension to give more or less friction, depending on what one wants if focusing and zooming.
06-29-2022 12:28 PM
The RF 100~500 does not have a lock switch to keep the lens barrel or objective from zooming when it's hanging.
~R5C (1.0.1.1) ~Many Lenses ~DxO PhotoLab Elite ~Windows10 Pro ~EVGA RTX 3080Ti FTW3 Ultra
~ImageClass MF644Cdw ~Pixel6 ~6D2 (v1.1.1) retiring
06-29-2022 03:10 PM
06-29-2022 03:38 PM
Thank you, Trevor. Super helpful and solved the problem!
06-30-2022 03:09 AM
Great you have a solution. Perhaps you can mark my post as the resolution to your issue, so that others don't keep trying to solve it and anyone else with a similar issue can find the solution fast.
06-30-2022 02:03 AM - edited 06-30-2022 11:52 PM
This lens is generally used for sports and wildlife photography. But as you can see, it does a great job for portraits as well. The level of background separation is unreal and the subject really pops in the images. SurgeCardInfo Login
06-30-2022 02:28 AM
Thanks Trevor, I was not aware you could tighten it to a "locking" point. I thought it only allowed you to adjust drag.
06-30-2022 03:08 AM
Thanks Rick! 🙂 I knew that the previous EF 100-400 lenses and 28-300 units that I have worked that way, and I have my own RF 100-500, so I had the benefit of first-hand experience.
