Search instead for
RF100-500mm F4.5-7.1 L IS USM Lens
jenben
Hi, I just bought this lens and when I carry the camera with lens attached, the inner barrel of the lens slips to full extension. Is this normal or should there be enough friction to hold the inner barrel in place? I would like to be able to move around with it over my shoulder and not have this happen--I'm sure it's not great for the lens and it's a little annoying. TIA.
Tronhard
Actually, the Rf 100-500 has a white knurled ring, jut behind the focusing ring.  It provides a variable friction effect to dampen or stop the lens from extending.  There is a lot of heavy glass in the front barrel of the lens, so it will want to drop if being carried.  The benefit of the ring, as opposed to a switch, is that one can vary the tension to give more or less friction, depending on what one wants if focusing and zooming.
cheers, TREVOR
Professional photographer, engineer and educator since 1980
"All the beauty of life is made up of light and shadow", Leo Tolstoy;
"A good swordsman is more important than a good sword" Amit Kalantri
Technique will always Outlast Tech - Me
7 REPLIES 7
The RF 100~500 does not have a lock switch to keep the lens barrel or objective from zooming when it's hanging.
~R5C (1.0.1.1) ~Many Lenses ~DxO PhotoLab Elite ~Windows10 Pro ~EVGA RTX 3080Ti FTW3 Ultra
~ImageClass MF644Cdw ~Pixel6
~6D2 (v1.1.1) retiring
Tronhard
cheers, TREVOR
Thank you, Trevor. Super helpful and solved the problem!
Great you have a solution.  Perhaps you can mark my post as the resolution to your issue, so that others don't keep trying to solve it and anyone else with a similar issue can find the solution fast.
cheers, TREVOR
Aaron748
This lens is generally used for sports and wildlife photography. But as you can see, it does a great job for portraits as well. The level of background separation is unreal and the subject really pops in the images.  SurgeCardInfo Login
Thanks Trevor, I was not aware you could tighten it to a "locking" point.  I thought it only allowed you to adjust drag.
Thanks Rick!  🙂  I knew that the previous EF 100-400 lenses and 28-300 units that I have worked that way, and I have my own RF 100-500, so I had the benefit of first-hand experience.
cheers, TREVOR
07/28/2022: New firmware version 1.2.1 is available for EOS-R3
07/21/2022: New firmware version 1.6.0 is available for EOS-R5
07/21/2022: New firmware version 1.6.0 is available for EOS-R6
07/21/2022: New firmware version 1.1.0 is available for EOS-R7
07/21/2022: New firmware version 1.1.0 is available for EOS-R10
07/01/2022: New firmware version 1.3.0 is available for PowerShot PICK
06/30/2022: Service Notice: EOS 70D: Error 70 or Error 80
06/07/2022: New firmware version 1.0.3 is available for EOS M50 Mark II
04/26/2022: New firmware version 1.0.1.1 is available for EOS R5 C
02/07/2022: New firmware version 1.6.1 is available for EOS-1DX Mark III
01/05/2022: Welcome to CES 2022!
12/7/2021: New firmware version 1.3.0 is available for Mount Adapter EF-EOS R 0.71x
