RF Lens Mount - Use an EF Converter and use RF Lens or use a 2x converter for a long zoom
shed
I have a 55-250 EF Lens I used for my Rebel (it's 10 years old).
I'm getting an R6 with the 24-105 EF L Lens, and I want to get pros/cons on whether I should use the $99 EF-RF converter or get the $599 2x converter and use my 24-105.
I don't think I'll need telephoto often, just for some of my kids sports, and there's no cheap long range zoon in the RF mount (which would probably be my ideal).
6 REPLIES 6
Waddizzle
The EF-S 55-250mm lens on a Rebel is roughly equivalent to the zoom range of the EF 100-400mm lens on a full frame camera body.  I do not think it wil be very use on the full frame R6, as the image will be significantly cropped because of the smaller EF-S image circle that it projects.  Give the EF 70-300mm f/3.5-5.6 IS II USM lens a look.
I recommend the mount adapter with the control ring, not the least expensive one with the control ring.  It will add the functionality of a custom control ring to any EF/EF-S mount lens.
@Waddizzle wrote:
@shed wrote:
I
Not on an R, It will limit you to an APS-C frame.
@kvbarkley wrote:
@Waddizzle wrote:
@shed wrote:
I
Yes, I know.  I said as much.
ebiggs1
"...get the $599 2x converter and use my 24-105."
Are talking the Canon Extender RF 2x ?  You might want to check but I don't think you can use it on a 24-105.
Depending on what you want to use it for but 200mm is not much of a telephoto.  You will need to be pretty close or your subject pretty big.
EOS 1DX and many lenses.
Dublinny1978
Hello, I have a Canon 5d Mark IV and I love it but it’s inevitable that I’m going to get the r5. Will the eye detection still work on the R5 with my current EF lenses if I get the lens adapter?
Oh thanks for that on what the 2x would work on. I just assumed it would be any lens. You're right, I checked.
OK in that case I'll just use my old lens on the converter until Canon come out with a reasonable priced long zoom for RF.
