RF 70-200mm 2.8 intermediate focal length change issue
gatens
Just found I can not specifically turn it/stop at specifically 85mm focal length.
The LCD shows focal length change not linear while I slowly turn the focal ring.
Example: 70 -> 75 -> 78 -> 81 -> 83 -> 84 -> 86
I have tried my another RF 24-70mm. It works perfectly can land in a specific focal length.
Is that normal for 70-200mm f2.8 tho ?
3 REPLIES 3
NatalyaP
Greetings gatens.
Please check to ensure that the zoom ring is clean from debris. If possible, please test the RF70-200mm F2.8 L IS USM lens on a different camera to see if the same issue occurs, since you state that the RF 24-70mm f/2.8L IS lens is able to display the focal length of 85mm.
In case the RF70-200mm F2.8 L IS USM lens is still unable to land at specific focal lengths, then you may send the lens to our facility for repair. I am unsure of when the lens was purchased but items purchased directly from Canon USA or from an Authorized Canon Dealer do include a one-year warranty if the item was purchased less than a year ago. You may view a list of Authorized Canon Dealers by clicking on the following link. I would recommend including a copy of your Proof of Purchase when sending in your item for the facility to review for any in-warranty service or repair.
https://www.usa.canon.com/internet/portal/us/home/contactus/where-to-buy/authorized-dealers
Canon U.S.A., Inc. has created a new online repair portal that allows you to set up service in a few simple steps. The repair portal gives you the ability to set up service for multiple pieces of equipment at once, and to receive a repair estimate in the majority of cases, depending on your model and issue. The portal also allows you to upload images or videos that will assist us in repairing your product. You can also select how you wish to be notified of the progress of your repair. The portal's service history section allows you to view all services that have been performed on any of your camera or video products since January 7, 2020.
Please follow the link below to access our online repair portal to arrange for service:
https://mycanon.usa.canon.com/signin
Instructions for Accessing and Using the Online Repair Portal.
You will need to access or create your My Canon Account.
If you already have a My Canon Account and your product is already registered, simply click on the “Get Repair Services” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you have a My Canon Account and your product is not registered, you must register your product first. Click on the “Get Repair Services” link on the left menu, then click on the “Register Product” link on the right. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you do not have a My Canon Account, you will need to create one. After you create your account, click on the “Add Product” link to register your first product. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
Once you have completed the repair request, you will have an opportunity to print a copy of the request for your records. This request form will also contain shipping instructions and an address label that you will attach to the outside of your shipping box when mailing your equipment for repair.
wq9nsc
Does the lens appear to zoom smoothly in terms of what is seen as you move through its zoom range?  I suspect that it does and the "issue" is with the encoder and display section which likely wasn't expected to provide a highly accurate readout in single mm increments.  Your lens is probably actually capable of "zoom" movement in fractions of a mm (that would be limited by the gearing involved in the zoom mechanism AND your ability to move the zoom control in extremely small increments) but that would be shown by the display.
I would definitely have someone else with the RF 70-200 f2.8 try your experiment to see whether it behaves the same way before sending your lens in for repair.
Rodger
rdominy
I have the RF 70-200 2.8 Z lens and it has no problem landing on 85mm and other specific focal lengths.  If this is the non-Z lens, perhaps the stiffer zoom ring makes it harder to hit specific values.
