02-25-2015 10:18 AM
Do circular polarizing filters come in various strenghts or ranges of change? ARe all C-polarizing filters the same? Yes, I know how to use them. I know the 90degree angle to the sun and all that ...I feel that I should be able to rotate the filter and see through the lens excactly what the change will be...frankly I find it very difficult to see the amount of change in the blue of the sky using the filter that I have....shouldn't you be able to rotate the filter and observe the change gradations? Shouldn't they be obvious as in a ND filter? Should I ask for a "stronger" polarizing filter?
11-20-2016 09:41 AM
@iris wrote:It occurred to me the other day that if the 90 degree angle rule to the sun is always applied, one can only get good blue sky effect faceing North or South....youll never be 90 degrees to the sun facing East or West?
I find some of the best use for polarizing filter for seeing though windows or removing glare from surface water.....
You can get dramatically blue skies during the golden hours, too.
11-20-2016 09:54 AM
"...one can only get good blue sky effect faceing North or South....youll never be 90 degrees to the sun facing East or West?"
Yo always get blue skies in Photoshop!
10-26-2018 06:14 PM
I followed the method you have posted and it did not work out for me and I am a user of canon error b200 and I purchased it 2 months ago.
12-05-2018
12:39 PM
11:55 AM
@iris wrote:Do circular polarizing filters come in various strenghts or ranges of change? ARe all C-polarizing filters the same? Yes, I know how to use them. I know the 90degree angle to the sun and all that ...I feel that I should be able to rotate the filter and see through the lens excactly what the change will be...frankly I find it very difficult to see the amount of change in the blue of the sky using the filter that I have....shouldn't you be able to rotate the filter and observe the change gradations? Shouldn't they be obvious as in a ND filter? Should I ask for a "stronger" polarizing filter?
[links removed per forum guidelines]
I look through the lens and turn it how much I am affecting the "blueness of those patches". I thought you were supposed to be able to see those changes as you rotate the lens...but I have not found much success noting those changes using the LD display or through the lens
12-07-2018 08:42 AM
[links removed per forum guidelines]I look through the lens and turn it how much I am affecting the "blueness of those patches". I thought you were supposed to be able to see those changes as you rotate the lens...but I have not found much success noting those changes using the LD display or through the lens
Remember that when you're looking through the lens, the lens is at full aperture, which is not necessarily the aperture at which the image will be captured. You might get more accurate results by using the preview button.
03-22-2019 05:05 AM
Polarizing filters, first of all, are made to reduce reflections. A polarizing filter can occasionally be used when a longer exposure is necessary. For example, when photographing waterfalls, it is an indispensable tool. If you are thinking that a polarizing filter is just needed to create the sky bluer, you certainly require some help in understanding their principal function.
eplaylist cari-mp3 downloadlagu-mp3 xepozone03-22-2019 08:29 AM
03-21-2020 04:10 AM
08-13-2020 03:15 AM
11-24-2020 10:23 AM
If you used a polarizer in the film days you might be disappointed by they way they work with digital because the effect isn't as dramatic. Same goes for comparing a polarizer to polarized sunglasses.
I have no idea if this is correct, but I assume the reason is that lenses today are better at cutting through glare.
They still have their uses and they still make blue skies bluer and let you see past the glare on water so I don't leave home without mine.
But yes, you're correct, they don't change images as much as I remember them doing in the 80s.
