10-23-2024 10:56 AM - last edited on 10-23-2024 12:42 PM by Danny
Hello! I’m kinda new to my camera but not really. I have a Rebel T7, but my zoom lens won’t focus. It’s on Autofocus and i’ve tried switching modes, cleaning the lens, restarting the camera and resetting all the settings but the lens won’t zoom in at all. I used the lens a solid 20 minutes ago and it was perfect, but now it won’t focus. My other lens will focus and work fine but my zoom lens won’t.
10-23-2024 10:58 AM
Thanks for joining the conversation, oliviab32!
So that the Community can help you better, we need to know exactly which lens model is giving you this problem. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
10-23-2024 11:09 AM
This is the lens, i’m not sure of the model if it’s not on there haha, i just know it’s a zoom lens but i’ve tried everything.
10-23-2024 01:05 PM - edited 10-23-2024 01:08 PM
To reinforce my colleague's comment. On the front of the lens there is something labelled MACRO (it's shown in your photo) - it's an add-on lens designed for taking very close-up images, and should be removed immediately by unscrewing it. They are rubbish, so never put it back on again. With that done, your camera and lens should function correctly.
I recommend you watch this video, given your level of knowledge - you have a bit of a learning curve and this will help:
10-23-2024 05:19 PM
THANK YOUUUU!
10-23-2024 11:09 AM
Are you on Full auto A+ mode?
Do you have enough light?
Does it try to do anything?
10-23-2024 11:11 AM
It’s on AF and yep i’ve tried going outside and it’ll go in and out like it tries to focus but it will only go out one second then back in and stops trying to focus.
10-23-2024 12:22 PM
Do you have a screw on Macro adapter on the lens? If so, that probably only allows focusing at close distances (besides probably having poor image quality). Remove the attachment and see what happens.
10-23-2024 12:40 PM
Try John's suggestion.
10-24-2024 10:18 AM
The best advice whether this is your problem or not is to never add anything to the front of your lens except a hood or cap. There is a small argument as to whether certain filters are good but even they are severely limited to a very few or even only one type. Just don't do it.
