07-10-2024 02:45 PM - last edited on 07-10-2024 02:55 PM by James_C
Hi, can you tell me from what part of the lens Canon EF 24-70mm F2.8L II USM is this plastic part? I find it between the rear glass and aperture unit.
07-10-2024 03:29 PM
Looks like an eccentric bushing used for adjustments.
You might be able to look through the pictures here and find it:
https://www.lensrentals.com/blog/2013/01/24-70mm-f2-8-lens-teardown-comparison/
07-10-2024 05:16 PM
I find from where is this small part. Its on rear glass part
07-11-2024 06:30 AM
Check your Private Messages.
07-11-2024 06:48 AM
Good info but it says nothing about this small part. Do you know what is this part used for?
07-11-2024 09:14 AM
I told you, it is an eccentric adjustment, used to make small changes in alignment that are then locked down.
07-11-2024 11:31 AM
Thanks!
