08-29-2016 09:51 PM - edited 01-19-2017 07:39 PM
08-31-2016 06:19 AM - edited 08-31-2016 08:56 AM
@Bannach wrote:I thank the friends who are anxious to help me in the sense of find out why the Serial my lenses do not appear the Exif.
After a more thorough search, I found that the serial lens is inserted manually in the camera settings, however my EOS - 5D Mark II, does not offer this function and do not know if have any further update (firmaVer) I'm using version 2.0. 9.PrScn follows, referring to the serial number input mode (this refers to EOS - 5D - Mark III)
Thank you all!
This is what I was getting at earlier. You do realize that any EF 24-105mm f/4L will look identical to the camera. Right?
08-30-2016 04:50 PM
I used the ExifTool 10:25 version for both tests.
I've watched the ExifTool the serial number Lens, Lens canon 70 ~ 200mm 100 ~ 400mm, 400mm, and other models.
08-30-2016 04:56 PM
Not the version of EXIFTool, but the EXIF version reported in the EXIF data, like the 221 I reported above.
08-30-2016 05:11 PM
Ok!
EXIF version - 0230
08-30-2016 05:18 PM - edited 01-19-2017 07:36 PM
08-30-2016 08:30 PM
Thank you all!
Thank you all!
