09-18-2013 02:15 PM
Are the focal lengths specified for the EFS lenses true focal lengths, or have they been adjusted to be 35mm equivalent? For example, if an EF lens with a specified focal length range of 18mm-55mm is mounted on an EOS 70D which has a 22.5 x 15mm sensor, does the angle range from somewhat wide to somewhat telephoto, or does the angle range from very wide to barely over standard.
I had assumed that the focal lengths listed are true, but then I noticed Canon describing a lens labeled 50mm as "standard" which would be the case for 35mm film, but not for a 22mm sensor.
(Sorry for asking such a basic question. I'm new to DSLR.)
- Ehz
09-18-2013 03:53 PM
The focal lengths on the lens are true focal lengths. They're the same regardless of EF or EF-S. Putting them on a crop sensor will narrow the FOV. So the 18-55 on a 70D will behave something like a 24-70 would on a 35mm camera (technically it'd be like 28 - 88).
09-18-2013 04:01 PM - edited 09-18-2013 04:02 PM
09-18-2013 03:53 PM
09-18-2013 04:14 PM
09-18-2013 04:37 PM
Great!
Skirball and RexRig, thank you both for posting.
- Ehz
09-18-2013 04:47 PM
As Skirball says -- they're "true", but everything in photography is rounded off.
It's not unusual for careful testing to determine that a 100mm lens is really (and I'm making this up as an example) 97mm, etc. f-stops are also generally rounded to the nearest whole or 1/3rd stop increment. They'll always be so close that the difference wont affect the exposure.
A focal length is considered to be "normal" or "standard" when it's angle of view approximates the angle of view of the human eye (and that assumes you're looking directly ahead and not moving your eye around). The angle of view is in the range of 40-50 degrees.
When a lens provides the same (or very close) angle of view, so that the camera sees approximately what the eye can see, they considered it to be a "normal" angle (because it seems normal enough to us.)
On a full-frame (sensor is the same size as 35mm film negative frame) camera, that turns out to be about 50mm. On an APS-C crop frame it turns out to be around 31mm (and there is no 31mm lens -- so anything in the range of 28mm to 35mm is close enough.)
