Hello. I have blurry photos with my Canon Zoom Lens EF 70-300mm IS USM.
davidtakesphoto
Is this a normal result from this lens?
I looked at the other tread and this lens seems to be far more blurry than the ones posted.
I appreciate any help in determining the issue!
Thanks.
David
Your issue is not sharpness it is contrast. Is there a fog or mildew on the lens?
Do you have any special style settings? Try using green square.
10 REPLIES 10
kvbarkley
VIP
VIP
How close were you when you took this?
I was 5-6 feet away...full zoom...
David
The closest focus distance is 5 feet, you might be too close.
diverhank
I could be wrong but the picture appears to be washed out (lack of contrast) but not exactly blurry?
I downloaded it and did a quick contrast and brightness adjustment:
Diverhank's photos on Flickr
Thanks....I tried that too.
Seemed like it should be clearer than that without any "fixes"
ebiggs1
You need to check your exposure. There isn't anything wrong with being blurry or I can't tell until exposure is correct.  Your shots are over exposed.
