EOS R8 Lens recommendations for documentary-style photography
rambo007
My wife just got a Canon EOS R8. She’s already so good with it and loves it. I don’t know anything about cameras but want to get her a lens. She says she wants to get into “documentary style photography”.
Any advice on which lenses I should consider getting her? I want to get a nice one but **bleep** some of them are expensive. Hoping to spend less than $1k so any guidance is much appreciated!
[Removed per Community Guidelines]
17 REPLIES 17
"A lot of older EF lenses DO NOT SUPPORT the highly advanced AF system in the EOS R series."
That would have no bearing on document photography but I, too, do not recommend any EF lens or any adapted lens for this job.
EOS 1DX and many lenses.
mdphotography
Rising Star
Rising Star
If she's shooting "documentary style", she'll probably be dealing with less-than-ideal lighting conditions.  I'd suggest something with an aperture no smaller than f/2.8.  You'll also want to get something with a wider angle of view because she may be working with limited space/mobility, like maybe 18mm (or even 10mm).  Unless she's shooting wildlife or nature documentaries, she probably won't need much zoom - maybe 105mm...135mm at the most.
IE: I use an 18-50mm f/2.8 for my street photography and it has more than enough range and light for my needs
APS-C lenses on Full Frame is not desirable. Due to the reduction in megapixels. Using that lens would result in a 9 megapixel image. When you can get the full 24 megapixels with a Full Frame lens.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
I'm not recommending a specific lens, just the features to look for.
"...she may be working with limited space/mobility, like maybe 18mm (or even 10mm)."
I would not recommend any UWA for documents. Distortion at the edges can be a problem if it is type or words as perhaps using the most open aperture. That is why a 50mm lens is considered the best all-around choice for document copying due to its minimal distortion. One of our copying stands even had a 75mm lens on it.
Not "documents", but "documentary"
Though, you might want some documents in your documentary. 8^)
Good point about edge distortion, but the OP said She says she wants to get into “documentary style photography”.  I shoot in this style and it's more about capturing moments as they happen than it is setting up the perfect scene; wide angle is essential.  In fact, my next purchase will be a 10-18mm; I have a mirrorless and with the crop factor 18mm is more like 29mm; it's wide enough, but I want a little more.
I really can't comment on photographing documents - I've never tried it.
I really do know how to read but it doesn't show sometimes. 🙄
