EOS R6 Mark ii Wide Angle Lens Recommendation
JeroneKingsby
Enthusiast
Please Reccomend a Ultra Wide and Wide Angle Lens
- R6 Mark II -
7 REPLIES 7
rs-eos
I would visit the Lens Buying Guide page.
Ricky
I was being Lazy and wanted to get quick easy responses  ...
also to see what others are using
I hear the R6 mark II Lens Choices are very few. Maybe someone, currently, using a wide lens for the R6 Mark II could share their thoughts and/or recommendations
These are some wide angle lenses listed.
  1. Native RF Lenses: RF 15-35mm F/2.8L IS USM, RF 14-35mm F/4L IS USM, RF 15-30mm F/4.5-6.3 IS STM, RF 16mm F/2.8 STM
  2. Adapted EF Lenses: EF 16-35mm F/2.8L I/ II/III USM, EF 16-35mm F/4L IS USM, EF 17-35mm F/2.8L USM, EF 11-24mm F/4L USM, EF 17-40mm F/4L USM
-Demetrius
Current Gear: EOS 5D Mark IV, EF 16-35mm F/2.8L III USM, EF 24-70mm F/2.8L II USM, EF 50 F/1.8 STM, EF 85mm F/1.8 USM, EF 70-200mm F/2.8L IS III USM, 430EX III-RT, 470EX-AI & 600EX II-RT
Retired Gear: EOS 40D, Sigma 17-50mm F/2.8 EX DC OS HSM & EF 28-135mm F/3.5-5.6 IS USM
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
I replied early this morning, a few hours after Ricky...  but didn't post my message.  Got a call .. and left the house.
Wide Angles - The RF 15~35 L f2.8, 14~35 L f4 and RF 15-30  f4.5~6.3 are available now.
UWA - Also note that there is a credible rumor that a RF 10-24 L f4 will be announced next month.  Sure its a ways off, but something to keep in mind if you aren't in a huge hurry.
There is one prime a 16mm.  2-3 other RF primes should be announced shortly.  Not sure if he's looking for zooms or fixed FL.
FloridaDrafter
- R6 Mark II -
I ended up buying the RF 15-35mm f/2.8L IS USM because I shoot a lot in low light. The 14-35 f/4 is a bit cheaper, so if lower light isn't a priority, it may be a better option. Also, the 14-35 is more compact and lighter and when you are zooming, the barrel doesn't extend as far as the 15-35, so if you are using a gimbal, balance isn't thrown off when you zoom (if that makes sense). I'm not that into landscape photography and usually shoot subjects a bit closer with this lens. For that, the 15-35 is as sharp as they come. I've used it on the R5, R6, and R6 mark II.
Newton
JoeySnaps
Enthusiast
There is, as others have commented, a wide choice of wide angle and ultra-wide lenses for your perusal.
I have the RF 14-35mm f/4 L lens which is quite splendid in every way.
I also have the RF 35mm f/1.8 STM lens which is also very good, also small light and affordable, and focusses right down to 1:2.
R6mkII, various lenses, speedlites. Also legacy Canons going back to T90 and even A1.
