12-28-2023 07:32 AM - last edited on 01-02-2024 08:49 AM by Danny
I have a Canon R10. Looking for guidance on lenses for my R10. I do mostly rock n roll performance photography and band photography.
cant afford these 3000 lenses yet
12-28-2023 12:47 PM
WordmanPhoto,
You can get an RF 50mm f/1.8 for about $170 and an RF 35mm f/1.8 for about $450.
Those should be pretty good for low light photography indoors, if you can get relatively close to the performers.
Steve Thomas
12-28-2023 01:19 PM
Don't dismiss all the EF lenses on the market as well, that can open up some third-party options as well as a much more robust used market. An EF 70-200 f/2.8 L IS II is a great lens and can be had for around $1000 USD on the used market. These EF lenses work just as well, or better, on the R-bodies in my opinion as they can be used with the much more advanced AF systems
12-28-2023 01:42 PM
Hi and welcome to the forum:
When you are photographing can you describe the conditions under which you do so? Particularly how close, the light etc.
Also what do you produce? Images for social media, for digital display, small-to-moderate prints, large detailed prints.
Thank you!
12-29-2023 02:58 PM
Thanks for the information. Most shots are in an amphora large club setting with pretty low light conditions except for the colored lights used. I’m usually anywhere between 5’ to 17’.
12-29-2023 03:21 PM
If needing to get up close (isolate subjects), I would recommend a zoom lens with wide aperture (e.g. 24-70mm f/2.8). Even with that wide aperture though, you'll probably need to raise ISO. If though you want to take images capturing more of the scene, a prime lens with a wider aperture would do very well (e.g. RF 35mm f/1.8)
12-29-2023 03:29 PM
Yes, not only is the distance to subject an issue, but whether the shots are going to be head shots, full individuals or the whole band. If all of the above (which I suspect that like me you are thinking) then a fast zoom lens might be the way to go.
Since we don't seem to have a definitive budget - "can't afford those $3k lenses" leaves a lot of wriggle room, it's hard to really know what is and is not affordable. If the need is for rock-bottom investment, a somewhat left-field option, apart from the economical and fast prime R units so far mentioned, might be the EF-S 17-55 IS USM f/2.8. Yes, it's old, but it's a great lens (often considered the best EF-S lens) and with a fast aperture. That might leave enough funds for something like an EF 70-200 f/4 MkII, which is small, reasonably fast and possibly affordable.
I grant that without a real budget this is all speculation...
12-28-2023 04:08 PM
@WordmanPhoto wrote:I have a Canon R10. Looking for guidance on lenses for my R10. I do mostly rock n roll performance photography and band photography.
First and foremost, you need to clearly state a budget. What lens do you currently own?
If you are only seeing the most expensive, then where are you looking? Canon offers several “STM” lenses under $1000 USD, and most retail for around $500 USD, or so.
