EF to RF Lens Adapters
Andrew_H
I was wondering if any of the canon ef to rf adapters worked for non-canon brands such as sigma?
10 REPLIES 10
Tronhard
VIP
VIP
Absoultely. I have shot with Sigma 150-600c and 60-600s lenses and the basic Canon adapter has worked flawlessly
cheers, TREVOR
Thank you so much! Do you think it would work well with the sigma ef 18-300mm lens?
I have not specifically used that lens but there is no reason why it should not.
The interface standards are very consistent.
cheers, TREVOR
What camera body do you intend to use the lens and adapter with?
cheers, TREVOR
The EOS R5.
As I understand it, the Sigma 18-300 is designed for an APS-C camera body and the R5 is a Full-Frame unit - this leads to some complications you may not be aware of.
In the case of DSLRs, your lens would not attach to a FF body at all.  In the case of the R-series bodies, the adapter will physically allow the camera to be attached to a FF body and will work.  The issue is with the sensor and the area of the projected image it will record.
An APS-C specific lens will have a narrower projection of the image to the sensor (because APS-C sensors are smaller).  Thus the FF sensor on the R5 will not receive an image across its whole surface area.
So, what happens is that the camera may sense that the lens is not designed for a FF sensor and will automatically go into crop mode, thus cropping the area from which it records your image.  This means that your pixel count will be significantly reduced - by a factor or 2.56 (the square of the crop factor).  Thus your R5, which has a 45MP sensor, will actually only record an image of 17MP.  If the camera does not sense that your lens is a crop EF-S unit,  then you can put the camera into crop mode via the menu system.
To learn more I recommend you download a copy of the R5 manual HERE and refer to P913 for an explanation of this.
If you want a comprehensive explanation of this relationship between mount, sensor size, lens focal length and Field of View (or Capture) see My Article on Equivalence   As part of the paper, I included a series of examples of how the relationship between sensor size and lens format works, and in your case example 6 is exactly your situation, although the camera cited is a R6.
cheers, TREVOR
The camera will not sense that the lens is designed for APS-C sensor bodies because the actual mount is EF, not EF-S.  All third party manufacturers use the EF mount,  no matter if the lens is designed for FF or APS-C bodies.
The camera will not automatically switch to crop mode.  You would have to change it in the menus.
Tronhard
VIP
VIP
If you want to have a lens + body combination that uses the whole capacity of the sensor of an R-series body, then you have two choices.
  1. Get the R5 and a suitable full-frame lens.  If you are going to do that, and can afford to, I would buy an RF lens; and to get something like the wide focal range you have been using (assuming that is what you want to continue with), then the RF 24-240 lens is a good unit and produces excellent results.  For a review of this lens see reviews from: Cameralabs or Justin Abbott
    If you have the funds, you could consider the RF 24-105 and the RF 100-400 combination.
  2. Get one of the new R-series APS-C bodies: the R7 or R10, and use your existing 18-300 with the adapter and that should then work to use the whole sensor.  The R7 is definitely the better of these two units, and with its 32MP sensor, it is the equivalent density of an 83MP sensor on a FF camera.  It has the same tracking and In Body Image Stabilization as the later FF RF units.  The R10 is a much cheaper and less capable unit, without the IBIS and is not as well built.
cheers, TREVOR
You are correct as usual.
I use EF-S lenses on my EOS R5. They work better than the same lens worked on my previous cameras. The 1.6x crop mode has a few less pixels than my EOS 80D and more pixels than my EOS 450D. I especially like myEF-S 18-135mm f/3.5-5.6 IS USM on the EOS R5.
I also use a 45 year old Minolta lens from a film camera with an Urth adapter on my EOS R5. The IBIS and manual focus aids are very helpful with this lens that has no electronics.
