03-12-2026 02:00 PM
I purchased this lens used about a year ago and have been noticing that I have images that are blurred at the bottom when shooting horizontal. I first assumed it was my camera shutter as I have a 1DXii that had a fairly high shutter count; however, I just obtained another and I’m seeing the result.
Anyone have any suggestions on what’s going on and if this is possibly an expensive fix?
Here is a link to a photo for reference: https://www.dropbox.com/scl/fi/pq9cdar782nuz55ufmrrw/Photo-Feb-28-2026-10-01-07-PM.jpg?rlkey=c63mvi8...
03-12-2026 02:42 PM
Since you've gone to the effort to post an image for us, please upload the RAW version if you have it.
Thanks,
~R5 C (1.1.2.1), ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, ~RF 200-800 +RF 1.4x TC, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve Studio ~ImageClass MF644Cdw MF656Cdw ~Pixel 10 ~CarePaks Are Worth It
03-12-2026 04:54 PM
Do any photos in vertical orientation show blur along the left- or right-hand sides?
Since you've tried with two different camera bodies, looks like a potential lens issue.
Also, is this at any aperture?
03-12-2026 08:58 PM
Here is a link to view 4 raw images, 2 vertical and 2 horizontal. I hadn't really noticed it in the veritical ones but it seems to impact them also.
03-12-2026 08:58 PM
03-12-2026 09:00 PM
Appears to be at both vertical and horizontal. I can't say about any aperture. I mostly shoot sports and don't often move off 2.8
03-13-2026 10:15 AM
First keep in mind most OOF issues are user caused and not equipment. That's not a slam it's just a reality. People make more misques than the gear does. You need to set up a test. You need to use a tripod and a 90 degree perpendicular to the lens target. A newspaper taped to a wall for instance. A brick wall can work.
There are so many things that can cause OOF and you stripped all exit info so there is little to gain from your samples except proving some of them are soft. Your issue could be as simple as you were at an angle to the girls which impacted DOF. It could be motion blur from too slow SS. It could be subject motion form the girls. Who knows without all the info. But, my friend, the first place to look is behind the camera/lens. Do the simple test.
03-13-2026 11:25 AM
I am curious if you looked at the RAW images I uploaded. They should have all of the information accessible. You can see that the shutter is plenty high to stop action and some of them are straight on and not shot at an angle. I will perform some additional tests, but it's pretty clear to see that the images are pretty sharp in some spots but as you move down on horizontal and to the right on the verticals that they get extremely soft more than they should.
03-13-2026 02:57 PM - edited 03-13-2026 02:59 PM
Another camera or lens? I'm assuming camera, just want to make sure I'm understanding 🙂
Newton
03-13-2026 04:13 PM
Correct. Same outcome on two different camera bodies.
