03-06-2026
10:41 AM
10:46 AM
Hello,
I am about to set of to take pictures of the Duomo in Monreale, Italy. I use a tripod and have heard or read somewhere that one has to turn off the image stabilizing when using a tripod and focusing manually. Is this indeed the case?
03-09-2026 10:24 AM
"...then having IS turned on is better."
And, you have an example, or examples, to prove that? How about posting it, or them, with all the details. If you have to go to a 100%, or more, crop to see any possible deterioration, it is not a good fator to make. We are talking real world real usage situations here.
03-11-2026 12:49 PM
I did some tests at home and could not see a difference. More depended on my manual focus. There is some shake on the tripod with the 70-200 lens, but once that calmed down and I used the remote shutter bulb, things came out pretty sharp both ways. Am heading up the hill from Palermo to Monreale tomorrow morning with my 5DSR, a wide angle, the 24-70 II, and the 70-200 II for shots that I will incorporate in a scholarly article. Always like to have the best images I can. Thanks for your input, dear Canon Community.
03-06-2026 10:48 AM
@hvulpus Anytime you use a tripod regardless of focus mode. You should turn off IS as it’s not needed when on a stable surface such as a tripod. Older versions of IS would hunt around to stabilize when camera shake is not detected.
03-06-2026 10:49 AM
"Is this indeed the case?"
I never do it but some insist you do it. I have done extensive testing and frankly I can not see any difference. It is simple to prove or disprove try it for yourself. I doubt you can tell any difference.
Why do you think you need a tripod once again something I rarely use? Unless in studio, that is. Are you wanting to shoot indoor stuff in rather dark conditions?
03-06-2026 10:58 AM
Yes, turn it off as that woud remove any risk of it interfering with things. Plus, you can conserve a bit of battery power.
03-06-2026 11:42 AM
Thank you.
03-06-2026 05:43 PM - edited 03-06-2026 05:44 PM
hvulpus,
Think of your IS like a gyroscope. It's constantly looking around, up and down, all around, searching out movement that it can counteract against. It's like it's on a snipe hunt, always looking for little snipes.
If you're shooting on a tripod, there's no movement to find, but it's still looking.
I did some experimenting a while back, and to my surprise, thought my pictures actually looked a little better when I was on a tripod and my IS was turned off.
Steve Thomas
03-07-2026 01:17 PM
"...my pictures actually looked a little better when I was on a tripod and my IS was turned off."
I'd like to see some samples and exact settings. It's not that I don't believe you it's I don't believe anyone on the ole inner web.
03-07-2026 01:22 PM
Here's the thing most people do things that they hear about or read about. Sometimes this clouds there assessment as emotion then starts to take over. It's sounds good so it has to be good or it sounds right so it has to be right. Now certainly everybody has the right to do as they see fit so if it floats your boat and you believe it makes a difference by all means switch it off.
03-07-2026 02:31 PM - edited 03-07-2026 02:37 PM
03-08-2026 12:49 PM - edited 03-08-2026 12:55 PM
Automatic IS deactivation is a feature of some lens, not the 1D X camera body. Some top end Canon RF lenses have or claim to have tripod detection ability to disable IS, I don't have any of those lenses.
I'll repeat, "Now certainly everybody has the right to do as they see fit so if it floats your boat and you believe it makes a difference by all means switch it off."
But I doubt you will see any difference especially on the shots where SS is higher, than say 1/100, and 1/1000+ I am certain you won't.
