EF 50mm 1.8 Manual Focus not Responding
Ziiar
Hello. I recently got an EF 50mm 1.8 lens for my EOS 60D.
The automatic focus appears to be fine but turning the focus ring while in manual does not change focus at all. I've made sure that the lens is set to "MF" and I can see "M FOCUS" on my top display. I tried the lens on another camera and it behaves the same way.
2 ACCEPTED SOLUTIONS
@Ziiar wrote:
Hi. Sorry, the shutter button problem I was having was a different issue that I have resolved now. Here is it's current state:
With the lens set to AF, the auto focus works fine. I can acheive this by pushing the shutter down half way.
With the lens set to MF, moving the focus ring does not change focus at all. Pushing the shutter half way while moving the ring, makes to change.
Does manual override work when the lens is set to AF? If not, then there must be a bad connection between the focus ring and the focusing motors. The focusing motors obviously work, or the lens would fail to autofocus. But I think a bad connection between the ring and the motors would explain the symptoms, including the fact that the failure is observed on more than one camera.
Bob
@kvbarkley wrote:
Call Canon customer service, you may have a bad lens.
If you just bought the lens, take it, or send it, back to the vendor for an exchange.
28 REPLIES 28
I just tried manual override in AF mode. Still no change.
ebiggs1
Simple!  The lens is faulty.  If it has warranty call Canon service.  If it is out of warranty it is not cost effective to have it repaired most likely.
perceptional1
Hello, I have a 5d mark iii the kit lens  and a fully manual samyang 14mm won't focus it just stays on focus when on maunual focus.  Turing the focus ring the image doesn't go in or out of focus it just stays in focus. It doesn't change the image at all. My cheap canon 50mm focuses properly,
I guess you mean the Samyang manual lens is not focusing.  Are you sure you're turning the focus ring, and not the aperture ring?  If the lens is new, sent it back for a new one or a refund.  The Samyang lens will not auto focus, and your camera should be in manual mode.
Hello
its not just the fully maual samyang it's also my kit lens  the 24-105mm L Lens both lenses won't go in out of focus it just stays
in focus, in contrast to that is my cheap canon 50mm focuses perfectly
Are you saying you cannot manual focus? Did you try setting the lens to manual focus mode?
Hello am on manual focus the samyang is fully manual it and my kit lens won't go in or out of focus it just stays on clear focus
If you want someone to help you,, then I suggest that you try to answer the questions you are asked.
Avatar
