01-07-2013 11:53 AM
I purchased 5D MK iii with kit 24-105 kit recently, i found many pictures has dark corners. is it normal? any one has tha same problem?
01-08-2013 08:04 AM
01-07-2013 04:12 PM
Probably. Vignetting can be common on wide angle lens wide open, especially on FF bodies. Do some testing by taking photos of a white wall with different aperture settings and compare those photos. Then take some photos at different focal lengths to see where the vignetting begins.
As long as the vignetting is the same in all 4 corners of the photo, the lens is not an issue. If it's uneven, the lens will need to be sent into canon for centering the elements.
Stacking filters or having a wrong lens hood (or even the correct hood improperly attached) can also cause vignetting. Do you have a filter on this lens? If so, is the ring thickness unusually wide? Do you get vignetting without the filter?
Some links to investigate further:
http://www.lenstip.com/240.8-Lens_review-Canon_EF_24-105_mm_f_4L_IS_USM_Vignetting.html
http://www.the-digital-picture.com/Help/Vignetting.aspx
http://www.bobatkins.com/photography/technical/lens_vignetting.html
http://www.canonrumors.com/forum/index.php?topic=6197.0
http://www.canonrumors.com/forum/index.php?topic=11898.msg212129#msg212129
01-08-2013 07:47 AM - edited 01-08-2013 07:49 AM
Thanks for your fast reply...
Am not using filters or lens hood and still have that annoying vignetting issue ... Am so suprised that vignetting is common in FF bodies wide lens ... anyway thanks for your reply ... i have to live with it 😄
01-08-2013 08:04 AM
01-08-2013 08:44 AM
Yes it only effects JPGs and I think lightroom is better then DPP ... am gona enable my PI and do some testing
Thanks Dear
