03-18-2019
01:17 PM
09:08 AM
Hello! I’m searching everywhere to find an answer to something I’m noticing on my new EF 16–35mm f2.8L USM iii. My question is: Have you found the newer 16-35 iii is slightly darker and has a slightly narrower field of view than the older version ii? Or is it just my particular lens?
I’m looking for someone who has direct and substantial experience with both the ii and iii versions. Here's more info and context:
I’ve shot my 16-35 2.8 ii for many years, mostly at weddings for close-quarters dance floor party shots, but also occasionally for big wedding party creatives & big vista creative shots. As most people know, it’s reasonably sharp in the middle but has soft spots outside of that; mine in particular has a really soft area on the right side.
So hearing that the iii has made substantial sharpness improvements, I purchased a new one. And I noticed it didn’t quite look/feel the same, so I ran some tests.
I mounted a body (5Diii) on a tripod and took various test shots with each lens (without any filters or changing any settings). In every test-shot set that I took, the new 16-35 iii had a slightly narrower field-of-view at 16mm than my older ii (i.e., you could not see as much around the outside edges of the images, as if it was zoomed in just slightly). And the iii images were also darker. [Note, I was also careful in some of the sets to be in manual focus and focused to infinity on both lenses, since changing focus can slightly change the FOV.] In Lightroom, toggling back and forth between 2 images in each set it’s clear that the field of view is slightly narrower and the histogram is darker on the shots from the new iii.
I sent both lenses to the Canon Service Center (CPS member) with my findings and test prints, hoping I had a defective lens that I could have repaired or replaced under warranty. But I was told that “under inspection it was found that your product performed accordingly.” And “due to the differences in shooting parameters, adjustment can be made in the camera setting to compensate the image exposure” (not sure what adjustments they're referring to?!)
So I’m wondering if it’s just my particular lens or if ALL iii’s are slightly darker and narrower FOV than the ii. And I’m faced with the choice of either: (1) returning the iii to Adorama for a new one, hoping the replacement is “better” but knowing it could just be how all iii’s perform, (2) keeping my iii and living with it, or (3) returning the iii and just going back to using my old ii. I’ve actually never been bothered by the softness around the edges of the ii for reception/dancing shots, I more notice it for the occasional big vista/wedding party shots.
Obviously I like that the iii is sharper. But it’s also bigger, heavier, and worst of all possibly darker & narrower FOV (either just mine, or all of them). Since I use this lens so much for reception dancing (close proximity to subjects and in dark environments) it’s crucial that it’s as wide and bright as possible.
UPDATE: I just got the following specs from the Service Center:
Max Magnification(at 35mm):
ii: 0.22x
iii: 0.25x
Field of view:
ii: 231 x 358 – 109 x 162mm
iii: 196 x 295 – 96 x 143mm
So there are in fact some obvious differences between the ii and iii, with the iii having more magnification and smaller FOV numbers. Seems obvious but I’m guessing this could explain the field of view difference that I’m seeing, and would possibly indicate, I think, that what I’m seeing in the images is for ALL iii’s, not just mine. …correct?
But would this also affect the issue of the images being slightly darker (for example, would the slightly smaller field of view = less light getting in…??)
03-23-2019 10:17 AM
@ebiggs1: Yes, I have all FF cameras, and yes I have really tight shooting conditions. On a crowded dance floor it isn't unusual for me to be packed between dancers that are literally only a few feet apart, or in small little hotel rooms or cramped bathrooms with a bride (and/or maybe a whole gang of bridesmaids). 24mm doesn't remotely cut it in those conditions.
And I didn't say I was experiencing distortion issues. The two issues are (1) narrower field of view, and (2) darker images. I'm glad Canon fixed the softenss that a lot of people see in the 16-35 ii. But I'm iritated at the trade-offs.
03-23-2019 10:47 AM
The wider angle lenses, 16-35mm, often have significant issues with field curvature and/or distortion. This can be seen as a reduction in IQ. Some are simply not great for large groups or being very close to your subject. More true at “fast” apertures. When you try to shoot a group photo at 24mm or less and you have people's faces at the edge of the frame, you're going to be distort them which may be the softness you see. Just laying out all possibilities for you.
If the problem is field curvature and/or distortion, it can't be fixed by a repair shop. Aslo, it is not uncommon for some lenses to not honor the FL printed on their outsides.
03-24-2019 10:49 AM
Yes I'm well aware of the distortion of that lens. I know the 16-35ii intimately, I've been shooting countless weddings with it as a pro for over 10 years. But again, I didn't say that was the issue. The softness of the 16-35 ii, which many people experience with that lens, isn't necessarily at the edges where it gets really distorted, it's in spots half-way or maybe two-thirds-way out from the center, at any subject distance (even when you're not close), and as far as I know is a very well known issue with that lens. If you read any review article about the iii they undoubtedly talk about the sharpness issues of the ii.
Thanks for your feedback but I'm really looking for people with substantial experience with both the 16-35 ii and iii, who can help me verify in a real hands-on sense what changed with these two issues.
03-27-2019 10:40 PM - edited 03-27-2019 10:41 PM
I can only speak for myself, I own the 16-35 f2.8L III, I cannot say I have experienced distortion, I only purchased the V III after enough research that it is in fact better regarding sharpness, which in my opinion it is.
I will offer a suggestion that may be of some help, on 500px when you click on an individual’s photograph and look at the Camera / Lens utilized you can click on the lens and see only photographs taken with that lens on the site, so perhaps you should look at what several others have regarding the photograph speaking for itself.
You can just paste these one at a time in the search bar, and it will show only the photographs taken with each lens, when you click on any particular photo, allow a few seconds for decompression as the site compresses stored images, takes less than 5 seconds for large size photos to come into focus, before I judge any lens, I want to see what others have experienced by what they have captured, and in this way you will.
Canon EF 16-35mm f/2.8L III USM
Canon EF 16-35mm f/2.8L II USM
IMHO you have a bad lens if in fact you are seeing distortion in any other place except the extreme edges, which in my experience are removed when applying a lens correction in post processing.
03-28-2019 12:50 AM
@Mitsubishiman wrote:I can only speak for myself, I own the 16-35 f2.8L III, I cannot say I have experienced distortion, I only purchased the V III after enough research that it is in fact better regarding sharpness, which in my opinion it is.
Compression results in loss of information, and decompression doesn't bring it back. So while I might trust that site to provide a reasonably accurate illustration of a lens's distortion (or lack thereof), I'm not sure I'd trust it to accurately depict the lens's sharpness.
03-28-2019 11:35 AM
The fact is the 16-35mm L II is the weak link in the Canon big 3 of the, f2.8L lens line up. The f4 version is just as sharp or sharper and cheaper. Also, the f2.8L II is pretty good if you don't use it at 22mm or below but who buys a lens not to use all it FL? Sorry Canon just not a fan of the 16-35mm f2.8L II.
03-28-2019 12:36 PM
@ebiggs1 wrote:The fact is the 16-35mm L II is the weak link in the Canon big 3 of the, f2.8L lens line up. The f4 version is just as sharp or sharper and cheaper. Also, the f2.8L II is pretty good if you don't use it at 22mm or below but who buys a lens not to use all it FL? Sorry Canon just not a fan of the 16-35mm f2.8L II.
I don't have that lens. (I have the f/4 version instead.) But I could swear that when the f/2.8L II first came out, everybody in this forum absolutely raved about it. Are we getting pickier in our old age? Or was the original f/2.8L just that much worse?
03-28-2019 01:19 PM
"... I could swear that when the f/2.8L II first came out, everybody in this forum absolutely raved about it."
I am guiltily.
When I first got it I was crazy about it. Then I started living with it. And, it is still great for stuff other than people. For landscapes and such it is fine. For brick walls it is not the first choice. And that is why it doesn't do people well. Work around don't shoot to the frame edges. But why have a 16mm lens if you have to stay above 20mm?
The Tokina AT-X 16-28mm f/2.8 Pro FX Lens for Canon is better, at worst as good, and costs less than half as much. I am not a Tokina fan but it is what it is. I have the Tok for both Canon and Nikon. It's better than the Nikon 14-24mm AFS f/2.8 G ED, too, at a third of the price! At this time that is the only Tokina I recommend and that advice plus a five dollar bill will get you a Starbucks.
03-28-2019 01:43 PM
For the things I do, the ii shoots people GREAT! Again, I use it mostly for wedding reception dance floors (very close quarters and dark), and I get outstanding shots with it. I also use it occasionally for large-group shots (huge wedding parties, or even just bride & groom big vista/scenery shots), and super small rooms like a bridal party cramed into a tiny hotel room. Yes, some of the wedding party in a big group shot aren't perfectly in focus in a couple of the spots. But the lens is small, light, bright, and a complete savior in those above-mentioned situations.
People here have gotten a little off-topic with regards to distortion. Again, my issue and reason for this post is that my new iii is slightly darker and has a slightly smaller field of view as my old ii (with test shots under the EXACT same conditions, focal length, focus length, etc.). And I'm still wondering if other people have noticed their iii is darker and/or smaller FOV than their ii. (And/or maybe I have a iii that's 'off' a little bit?)
And then aside from wondering if I have a sub-par iii, I'm ultimately left with the decision if it's worth the extra sharpness of the iii for the down-sides (darker, smaller FOV, larger & heavier lens than the ii).
03-28-2019 02:51 PM
I think you are right about it being darker than the II. Dpreview measures the T-Stop value:
"The lens' F-number is a theoretical value, and the actual light transmission value, known as the T-stop, is always fractionally lower due to light losses within the lens. Lenses with more elements, like a complex zoom, tend to be slightly more effected. The measured T-stop for this lens is F3.1 which means the lens is letting through a bit less light than the F2.8 rating suggests."
They don't have a comparable value for the II version for a direct comparison.
