12-31-2018 05:49 PM
I have seen a lot of people use Tamron and Sigma lenses and always wanted to know how they compare to a Canon lens, specifically in the 600-800mm range? I want the best quality pictures possible, but will I be disappointed with a non-Canon lens? I have a 5DSR and a 7D MII, so they aren't cheap cameras. This lens would be for mostly wildlife and I love getting good close up shots of the subjects. Suggestions, recommendations???
12-31-2018 08:04 PM
01-01-2019 06:07 PM
I forgot to mention, I currently have 2 Canon lenses a 24-70 and a 70-300mm. The 70-300mm is a little older, but I guess my main interest in a new lens would be to go beyond the 300mm. Being able to produce high quality images so that I can print them out if I want would be the ideal situation. In the real world, most of my images are digital only and I only end up printing a few, but I really hate having images that are not clear -- yes that is assuming I have done my job and the image is properly focused etc.
I am not a professional photographer so I don't know that I really want to spend the $13k on a Canon lens, which is why I was considering one of the other brands.
12-31-2018 11:11 PM - edited 12-31-2018 11:15 PM
Great choices on camera . I have exactly the same two.
I will give you my opinion on the subject... I have a Canon 100-400mm f/4.5-5.6 IS II, a 600mm f/4L IS (Version 1), a Tamron 150-600mm version 1 and a Sigma 150-600mm Contemporary. I also had a Canon 400mm f/5.6L that I used for years until I got the 100-400mm. This zoom lens is just as sharp @ 400mm.
Neither the Tamron or the Sigma will match the Canon lenses, especially the 600mm f/4L in IQ, focus speed and durability. However, the Tamron and Sigma 150-600mm is pretty decent, enough that I use them all the time (until the Tamron broke on me). They are so versatile. I wish Canon'd make a lens with that zoom range but Canon doesn't.
Once I did an experiment with the Canon 400mm f/5.6 @ 400mm and the Tamron @ 600mm side by side. I used photoshop and just magnified it by 1.5 to make the image equal to 600mm and its IQ still beats the Tamron...so when you hear people using the 1.4x instead of getting the 150-600mm, it is not far-fetched at all. Having said that, I don't use the 1.4X on my 100-400mm because I dislike the slowed down focusing speed and its hunting a little bit. The Tamron and Sigma focusing speed is better than the Canon with a 1.4X, in my experience.
You can visit my Flickr, look at different albums for different lenses. The pictures will give you some ideas of what can be achieved by the Tamron and the Sigma.
01-01-2019 08:01 AM
What is your assessment of IQ of the 100-400 with 1.4X compared to Sigma zoom?
01-01-2019 10:12 AM
, if is pre
@jrhoffman75 wrote:What is your assessment of IQ of the 100-400 with 1.4X compared to Sigma zoom?
That is a very good question. In my experience, the focusing system of the camera can be a factor. The more AF points you can put on the subject, the better the camera/lens combination is able to track and focus. Your AF points settings come into play AF point sensitivity wants to be a factor, too.
My action photography C2 custom shooting mode is Case 2. I think your AF settings can make a significant difference, and of course what it is that you are photographing. For me, it has become mostly football.
Wtih a 6D or 7D2, I get better results with the Sigma “C” than with the 100-400 w/1.4x. With a 6D2, I get better results with either lens over the 7D2 under most conditions. The 7D2 is only useful to me for its’ reach on sunny days.
With a 6D2, it is pretty close between the two setups, but the 100-400 w/1.4x has better IQ. But, you can take a small hit in AF speed, which I think only brings it down to the speed of the Sigma “C”. The Sigma might be a little faster at initial capture, but that is as far as it seems to go. Once the Canon is tracking, it stays locked on like pit bull.
The Sigma “C” had never been a fast focusing lens, but the firmware rewrite a couple of years ago completely changed the lens. Sigma claims a 40% increase in focusing speed, and I am not going to argue with them. The lens used to become soft at greater than 500mm, which caused to limit it to just 500mm, but not anymore. I also found that my copy tended to back focus at the short end, and front focus at the long end, but no more of that, either. In fact, I cleared all of the Sigma AFMA settings.
01-01-2019 10:26 AM
Thanks for an informative response. i appreciate the time you put into it.
01-01-2019 11:11 AM
Just out of curiosity, Waddizzle, does the 100-400 accept the same 1.4x as the 70-200 lenses do?
01-01-2019 11:19 AM
@RobertTheFat wrote:Just out of curiosity, Waddizzle, does the 100-400 accept the same 1.4x as the 70-200 lenses do?
I am using the 1.4x III, and it works on both lenses. I think you need to have that version with the newer 100-400mm. As far as I know, the main difference between each new version of the extenders has been firmware updates for new lenses.
01-01-2019 03:06 PM
Oh sorry, I should have mentioned this. With the caveat that I didn't really do careful comparisons, I feel that the Sigma IQ is slightly better than the Tamron V1 but not by a whole lot. So I'd say that its IQ is roughly the same as the 100-400 with the 1.4X . So I usually use the Sigma when I need the range because, to me, the Sigma focus is better than the Canon combo.
@I use the Canon 100-400mm II whenever 400mm is adequate. For close in work, this lens is incredible - being able to focus at all FL at a distance of just a tad over 3 feet. 400mm @ 3ft is like using a macro lens...
Happy New Year!
