12-19-2014 05:23 PM
Hi can't seem to get a sharp a image with my 70- 200 as I can with my 100-400mm. Should I be getting just as sharp photos with both lenses. I still have a warranty with best buy.
12-19-2014 06:04 PM
What are your shooting conditions? If you were below 1/400 or so the IS on the 100-400 could make a significant difference. Try a controlled test, on a tripod, same settings, IS off.
12-21-2014 10:20 AM - edited 12-21-2014 10:32 AM
"Hi can't seem to get a sharp a image with my 70- 200 as I can with my 100-400mm."
These two lenses should provide similar results as long as you are using them both the same way. Possibly the 70-200mm f4 would give slightly better sharpness. It is an easier lens to use as it has less focal length to influence your pictures. Generally everything is multiplied as the focal length goes up. Even the bad stuff! You need to compare them in exacting manner, though.
12-19-2014 06:04 PM
12-27-2014 07:15 AM
Thanks I will
12-27-2014 10:23 AM
@ebiggs1 wrote:"Hi can't seem to get a sharp a image with my 70- 200 as I can with my 100-400mm."
And re-calibrate the autofocus microadjustment for the 70-200, if your camera supports it. It's unusual for an "L" lens to require AFMA, but it's always worth checking.
