Canon EF 28-80mm Zoom Lens Ultrasonic
HalasPete
Bought this lens off eBay. Thinking it is first generation of the 28-80mm zoom ultrasonic. Is there a manual for this lens?
31 REPLIES 31
Tronhard
VIP
VIP
No that I can see with a fairly extensive search.   Is there a specific reason you need the manual?
cheers, TREVOR
HalasPete
No, but I was hoping for any additional information. I bought this lens used on eBay, looks like someone was enthusiastic with oil. Hoping the lens can be disassembled, cleaned, and be like new again.
Canon generally refuse to even clean a lens for which they cannot provide parts.  This is reasonable, considering they don't know what they will find.  This lens is really old and way past the service envelope now.
cheers, TREVOR
ebiggs1
"Hoping the lens can be disassembled, cleaned, and be like new again."
I really doubt it.
I have one of these. It is a good for the price lens. Better than most of the era.
EOS 1DX and many lenses.
normadel
Here is a Wikipedia page that shows the hierarchy and specs of EF 28-80 lenses:
https://en.wikipedia.org/wiki/Canon_EF_28-80mm_lens
Your lens is undoubtedly not worth what it would cost to be professionally disassembled to clean it.
HalasPete
I can accept that this lens is beyond repair. Took a chance. Is there a better version of this lens to look for?
I have 24mm prime, 50mm prime, 100mm macro, and a 75 to 300 zoom lens for my Canon 5d2. Was hoping the 28 to 80mm would fill in the blanks.
normadel
Did you look at the article and see newer lenses of that range? 28-80 is an old range in Canon's line. Newer offerings would make more sense.
I have an EF 28-135 f/3.5-5.6 IS USM that does a nice job. Made from 1997-2016. Plentiful on eBay, a bunch at MPB.com (a good used dealer). Reasonable-priced lens. More worthy of your 5D II than a 28-80.
ebiggs1
" I bought this lens used on eBay, looks like someone was enthusiastic with oil."
Return it. When you say "enthusiastic with oil" what does that mean? There is oil inside the lens? Or, oil all over the outside and some has creeped inside.  Most people don't oil their lenses.
Tronhard
VIP
VIP
Your lens is the first version of this specific model and is apparently the best - but is IS a very old lens. As Ernie wisely pointed out, it it not normal to oil a lens, which suggests this may have been done to avoid an issue of a mechanical fault in the lens.  The oil will likely migrate to places it should not, if that has not happened already, so I would certainly approach the vendor with a 'please explain'!  If that doesn't bear fruit, then  claim a refund from eBay if you can.
If you are looking for a lens, a couple of questions:
1.  What camera are you mounting it on?
2.  Are you looking specifically for a vintage lens: i.e. very old or just a bargain?
3.  What is your budget?
4.  Is there specific focal range you are seeking?
cheers, TREVOR
