Canon 100MM f2.8 L IS USM Lens Loose or Elements Shifting Noise
llehmann
Enthusiast
I recently picked up my Cannon 100mm Macro lens and heard a strange noise coming from inside. Sounds like the elements of something has come loose. When you give it a light shake... something doesn't sound right?
I Googled the problem and found this video which shows the exact sound I am hearing from my lens.
https://youtu.be/8E-4tUsoxoQ?t=41
Has anybody seen or heard of this? Does your lens sound like this? I never noticed the sound before?
Thanks
11 REPLIES 11
ebiggs1
Call Canon today 1 (800) 652-2666
Is this noise a common fix with the lens?
I have the lens, it doesn't make any sound at all when shaking it, you need to send it in to Canon
It sounds as though there may be a loose screw or something similar inside. It may never cause a problem, or it may scratch a lens element the next time you use it. That's a good lens and worth fixing, as most "L" lenses are. Unless you're a qualified camera technician yourself, take the others' advice and have it looked at professionally.
Bob
Emory2350
Thanks
I have lenses but i did not heard any kind of voice frome them.
Isaaydin
After using my lens for 4 years it started to make that noise when i am shaking it. But not when plugged to camera or any errors when shooting. I guess thats the next step. Who knows where should i ship it to fix?
greggyp89
I just picked up the lens brand new from Best buy and I am also hearing something shake inside. Sounds like something is loose
Hello greggyp89,
The sound you hear doesn't of itself suggest a problem. It is normal to hear a slight rattle in lenses with image stabilization. Some are more noticeable than others. This is not a problem. You can minimize the rattle by placing the lens on the camera, powering the camera on and turning the IS off while the lens is mounted to the camera. Then power the camera off. This "parks" the IS system.
Thank you! This was exactly the fix I needed. All the other comments about sending it in for repair were totally off base. You saved me a lot of headaches!
