01-13-2022 12:23 PM
Hello all,
I'm one of those people who worries about accidently damaging my camera gear. I just purchased an EOS R with the 24-105 L series lens and I was curious how easy it is to scratch? Should I be worried about scratching the lens when replacing the lens cap with a lens hood in a reverse position or is it safer to remove the lens hood to ensure it's put on correctly? In the event that the lens does get damaged I did purchase the care pak. Would canon replace the front lens element if needed? Thanks!
01-13-2022
01:00 PM
01:25 PM
Put a clear lens filter on the lens and use your camera. CarePaks are there for unforeseen accidents, but don't live life waiting for one to happen.
[Commercial link removed per forum guidelines and replaced with screenshot to facilitate discussion.]
~R5 C (1.1.2.1), ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, ~RF 200-800 +RF 1.4x TC, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve Studio ~ImageClass MF644Cdw MF656Cdw ~Pixel 10 ~CarePaks Are Worth It
01-13-2022 02:52 PM
But to answer your question, yes Canon can replace the front element, as long as the lens is still being supported. But note that it takes a *lot* of damage for it to be noticable.
01-13-2022 02:54 PM
I can definitely second Rick's recommendation above. I also personally use the B+W brand. I like their high-quality optics, and also their use of a different metal (brass) than what Canon uses for the filter threads on the lens. While not impossible to overtighten, it helps to not bind as much.
I even have spares on hand for the two sizes I need just in case.
01-13-2022 03:05 PM
Thanks for the reply. Have you experienced any quality issues with using a lens protector filter?
01-13-2022 03:06 PM
Thanks for the reply and recommendation! I’ve ordered a few of those filters. Any quality issues that you’ve experienced while using them?
01-13-2022 03:13 PM
I have not. I'm sure there are other brands beyond B+W that also have great optical quality. I haven't used them though.
But for these clear versions, Neutral Density (ND) (I only used fixed ND and not variable), and Circular Polarizers (CP), I've not noticed any image degredation.
While you don't need to spend a huge amount of cash on filters, I would advise against the very inexpensive ones since they could affect your images. After all, Canon has some very excellent glass elements throughout their lenses. So not a good idea to add a poor quality element to that.
01-13-2022 04:09 PM
Very good to know. Thank you
01-13-2022 06:16 PM
Thanks for the useful information.
01-13-2022 06:47 PM
Will the original lens cap fit over a filter? Or would I need to remove the filter to put the cap back on when storing in a camera bag?
