05-30-2024 12:00 AM - last edited on 05-30-2024 08:48 AM by Danny
I'm a novice and completely confused after researching this question
Can anyone please tell me what the combined mm and magnification this with this arrangement on my Canon R?
05-30-2024 11:24 AM
"Call me whatever you want, ..."
Hey no disrespect at all. I am all in for you as I say I've done some pretty out there stuff too and I suspect people thought I was nuts. Maybe they are right. 😁
I only offered an alternative using Photoshop.
05-30-2024 11:30 AM
As best as I can guess so far, I've read that a 25mm lens provides 10x magnification.
So based on that, I'm thinking that my setup here will logically provide a magnification of 672x, assuming 600mm × 2 × 1.4 and 10/25 = 672/1680.
Prove my method of calculation is incorrect, and I will consider your suggestion or correction.
Or, just say something critical about my intellectual level or whatever... 🤪
I'm a retired US Navy pilot, so I don't care about anyone's insults or about pointless blabbering about my gear not working. 🤣🤣🤣
05-30-2024 12:43 PM - edited 05-30-2024 12:53 PM
"As best as I can guess so far, I've read that a 25mm lens provides 10x magnification."
It is not so cut and dried. It is a factor of focal length, sensor size and minimum focus distance.
Trevor told you your new focal length. I wrote how to figure out how many pixels you will get for the moon for a given focal length:
05-31-2024 11:13 AM
"Prove my method of calculation is incorrect, and I will consider your suggestion or correction. "
Yes or I mean no, your calculation is incorrect, IMHO.
" It is a factor of focal length, sensor size and minimum focus distance."
"a 600mm lens plus a 2x = 1200mm. Add another 2x and it is 2400mm. add the third it becomes 4800mm."
On a FF camera 50mm is basically considered one power as it is thought to be the same view as the human eye. So 100mm is equal to a 2x telescope and 400mm is equal to a 8 power telescope, etc. Your combo yields 4800 mm and should be equivalent to a 96 power telescope. Of course this would also be influenced by the 1.6 crop equivalent of a cropper.
Now as to the extension tube it will depend on exactly where it is in the rig. It will only effect everything forward of it and nothing behind it. I have heard of birders using an extension tube on big tele lenses for shooting birds but I have no idea how well it works since you lose infinity. And in your case, I so want to see any Moon shots you get even if it is possible for you to get one which I doubt. Your f-stop penalty is going to be in the tank. I am guessing it will be more than f45 possibly f85 on the big Siggy lens.
Please post a sample.
