09-18-2022 01:18 PM
Hi All,
My 50 1.2 has stopped focusing completely. I can manually focus but the auto-focus is dead. There has been no 'trauma' to the lens. It was working one day and then nothing the next. Any thoughts/suggestions before I send it in to Canon?
Thanks,
Phil
09-20-2022 01:03 PM
"You also wouldn't be able to control the aperture automatically or manually."
That may or may not be true. I agree it is not a lens contact issue, however. It is almost to never a contact issue unless someone abuses them by cleaning them improperly!
The EF 50mm f1.2L is one of my very most favorite prime lenses. It is a somewhat difficult lens to master as focus can be critical. It is big and it is heavy. It is a very old design and yours needs to go to Canon for service.
09-18-2022 01:30 PM
Which camera body? Does the AF work with other lenses?
09-18-2022 01:39 PM
5D4 and 5DSR. All other lens are working with both bodies. Thanks for the response.
09-18-2022 01:49 PM
Hi, OP it sounds like a lens issue. Is the lens set to AF mode. The 50 F/1.2 is a USM lens that supports full time manual focus. Without the camera metering system being active. Does the camera even register AF at all.
-Demetrius
40D, 5D IV, EF 16-35mm F/2.8L III, EF 24-70mm F/2.8L II, EF 28-135mm F/3.5-5.6 IS USM, EF 50 F/1.8 STM
430EX III-RT & 600EX II-RT
09-18-2022 02:04 PM
I agree, I think it is in the lens. I am able to control the aperture fully and it is obviously affecting the image, (i.e., DOF and brightness). All AF controls are active but the lens itself is dead.
09-18-2022 02:06 PM - edited 09-18-2022 02:10 PM
Does the lens work on a different camera body if you have one or can access one. Are you using any 3rd party accessories if so remove them and try again from factory.
-Demetrius
09-18-2022 02:09 PM
yup, 5d4 and 5dsr
09-18-2022 02:16 PM
Will the lens AF on the other body you mentioned. Or does it continue not to AF but you still can control the aperture.
-Demetrius
09-18-2022 02:23 PM
AF dead on the second body and I can still control aperture. 😕
09-18-2022 02:25 PM - edited 09-18-2022 02:32 PM
It sounds like your AF motor is dead.
-Demetrius
